メインコンテンツにスキップ
Lenovo ThinkPad S145-15AST Battery Replacement
必要な工具と部品
  1. Lenovo ThinkPad S145-15AST Battery Replacement, Remove the back cover: 手順 1、 1の画像 1
    • Unplug and power off your device.
    • Touch a grounded object like a metal fridge to discharge any static electricity. Do not do the repair on carpeted floors, do the repair preferably on wooden floors.
    • The screws circled in red are 7mm M2.5's. The screws circled in orange are 4mm M2.5's.
    • Remove the screws with your Phillips #0 screwdriver.
    • Wedge an opening card (recommended) or spudger into the ridges of the case and carefully pop off the clips securing the back cover and make sure to not break any clips.
    • Remove the back cover.
  2. Lenovo ThinkPad S145-15AST Battery Replacement, Battery removal: 手順 2、 2の画像 1 Lenovo ThinkPad S145-15AST Battery Replacement, Battery removal: 手順 2、 2の画像 2
    • Pull at the connector of the battery, circled in red. It should just pop out. If not then don't force it!
    • Use your Phillips #00 screwdriver to remove the three 6mm M2 screws securing the battery, that are circled in yellow in the image.
    • Now just pull up on the battery and remove it.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard.
    • Align your new battery with the screw holes.
    • Install the three 6mm M2 screws into the screw slots.
    • Reconnect the battery connector.
    • Reattach the back cover and reinstall the ten M2.5 screws.
    • Now you should be all good to go!
終わりに
For best performance, calibrate your new battery after completing this guide.
Make sure to take your used battery to a e-waste recycling center.
作成者
1人の作成者と共同作成されました。
Oliver Fallon
メンバー登録日: 07/04/23
199 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 20
今までの合計 83
