はじめに
Is your Lenovo ThinkPad P50s keyboard not performing as expected? If you're dealing with a worn-out key or a complete keyboard malfunction, try out these solutions on the keyboard troubleshooting page. If those don't seem to work, follow this guide which walks you through the process step-by-step on how to replace your keyboard. With a minimal amount of tools, easy-to-follow instructions, and helpful tips, you'll be able to replace your keyboard with ease.
Before you begin this guide, you should disable the built-in battery. Here is a link with instructions on how to do so on page 123. You should also disconnect the AC power adapter and turn off the laptop.
必要な工具と部品
Use a spudger to push on the indents in the keyboard approximately 2.5 mm forward to reveal the 1.7 mm screws.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
