メインコンテンツにスキップ
Lenovo ThinkPad P1 Gen 7 SSD Replacement
必要な工具と部品
  1. Lenovo ThinkPad P1 Gen 7 SSD Replacement, Turn off your laptop: 手順 1、 3の画像 1 Lenovo ThinkPad P1 Gen 7 SSD Replacement, Turn off your laptop: 手順 1、 3の画像 2 Lenovo ThinkPad P1 Gen 7 SSD Replacement, Turn off your laptop: 手順 1、 3の画像 3
    • Shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
    • Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
  2. Lenovo ThinkPad P1 Gen 7 SSD Replacement, Loosen the base cover screws: 手順 2、 1の画像 1
    • Use a Phillips screwdriver to loosen the six captive screws securing the base cover.
  3. Lenovo ThinkPad P1 Gen 7 SSD Replacement, Loosen the base cover's left side: 手順 3、 3の画像 1 Lenovo ThinkPad P1 Gen 7 SSD Replacement, Loosen the base cover's left side: 手順 3、 3の画像 2 Lenovo ThinkPad P1 Gen 7 SSD Replacement, Loosen the base cover's left side: 手順 3、 3の画像 3
    • Press the tip of an opening pick into the seam between the base cover and the bottom-left corner of the frame (near the screen hinge).
    • It can be tricky to get the pick into the seam for the first time. Angle the pick vertically and press down with firm pressure.
    • Pivot the pick down and slide it around the corner to release the clips.
  4. Lenovo ThinkPad P1 Gen 7 SSD Replacement: 手順 4、 3の画像 1 Lenovo ThinkPad P1 Gen 7 SSD Replacement: 手順 4、 3の画像 2 Lenovo ThinkPad P1 Gen 7 SSD Replacement: 手順 4、 3の画像 3
    • Slide the opening pick along the left edge to release the clips securing the cover.
  5. Lenovo ThinkPad P1 Gen 7 SSD Replacement, Loosen the base cover's right side: 手順 5、 3の画像 1 Lenovo ThinkPad P1 Gen 7 SSD Replacement, Loosen the base cover's right side: 手順 5、 3の画像 2 Lenovo ThinkPad P1 Gen 7 SSD Replacement, Loosen the base cover's right side: 手順 5、 3の画像 3
    • Press the tip of an opening pick into the seam between the base cover and the bottom-right corner of the frame (near the screen hinge).
  6. Lenovo ThinkPad P1 Gen 7 SSD Replacement: 手順 6、 2の画像 1 Lenovo ThinkPad P1 Gen 7 SSD Replacement: 手順 6、 2の画像 2
    • Slide the opening pick along the right edge to release the clips securing the cover.
  7. Lenovo ThinkPad P1 Gen 7 SSD Replacement, Remove the base cover: 手順 7、 2の画像 1 Lenovo ThinkPad P1 Gen 7 SSD Replacement, Remove the base cover: 手順 7、 2の画像 2
    • Grasp the base cover along the screen hinge edge and pull up to loosen the cover.
  8. Lenovo ThinkPad P1 Gen 7 SSD Replacement: 手順 8、 2の画像 1 Lenovo ThinkPad P1 Gen 7 SSD Replacement: 手順 8、 2の画像 2
    • Lift and remove the base cover.
  9. Lenovo ThinkPad P1 Gen 7 SSD Replacement, Loosen the battery screws: 手順 9、 1の画像 1
    • Because of the battery connector's design, the only way to disconnect the battery is by physically removing it.
    • Use a Phillips screwdriver to loosen the six captive screws securing the battery.
  10. Lenovo ThinkPad P1 Gen 7 SSD Replacement, Remove the battery: 手順 10、 2の画像 1 Lenovo ThinkPad P1 Gen 7 SSD Replacement, Remove the battery: 手順 10、 2の画像 2
    • Grasp the top edge of the battery and lift to disconnect it.
    • You may feel a little resistance from the battery connector as it disconnects—that's normal.
  11. Lenovo ThinkPad P1 Gen 7 SSD Replacement: 手順 11、 2の画像 1 Lenovo ThinkPad P1 Gen 7 SSD Replacement: 手順 11、 2の画像 2
    • Lift and remove the battery.
  12. Lenovo ThinkPad P1 Gen 7 SSD Replacement, Model differences: 手順 12、 1の画像 1
    • Depending on the model, your laptop may have two SSD slots. The replacement procedure is the same for both of them.
  13. Lenovo ThinkPad P1 Gen 7 SSD Replacement, Remove the SSD cover: 手順 13、 1の画像 1
    • Use a Phillips screwdriver to loosen the two captive screws securing the SSD cover.
  14. Lenovo ThinkPad P1 Gen 7 SSD Replacement: 手順 14、 3の画像 1 Lenovo ThinkPad P1 Gen 7 SSD Replacement: 手順 14、 3の画像 2 Lenovo ThinkPad P1 Gen 7 SSD Replacement: 手順 14、 3の画像 3
    • Lift and remove the SSD cover.
    • You may feel slight resistance, as there's a thin thermal pad between the top of the SSD and the cover.
    • During reassembly:
    • Make sure the bottom of the cover has a thermal pad. If the pad remained intact on top of the old SSD, carefully transfer it to the cover.
    • If you're replacing the pad, make sure the new one is the same thickness as the old pad.
  15. Lenovo ThinkPad P1 Gen 7 SSD Replacement, Remove the SSD: 手順 15、 3の画像 1 Lenovo ThinkPad P1 Gen 7 SSD Replacement, Remove the SSD: 手順 15、 3の画像 2 Lenovo ThinkPad P1 Gen 7 SSD Replacement, Remove the SSD: 手順 15、 3の画像 3
    • Two thermal pads bond the bottom of the SSD to the motherboard. Depending on their age and condition, it may take some force to separate the SSD from the pads.
    • Grip the SSD by its edges near the screw notch and lift to separate it from the thermal pads underneath—it should pop up at a slight angle.
    • Lift with gradual force. If the SSD detaches from the pads unexpectedly, you may pull up too hard and damage the socket.
    • If the SSD isn't budging, try using the flat end of a spudger to pry up the edge of the SSD with the screw notch.
  16. Lenovo ThinkPad P1 Gen 7 SSD Replacement: 手順 16、 2の画像 1 Lenovo ThinkPad P1 Gen 7 SSD Replacement: 手順 16、 2の画像 2
    • Grip the SSD by its edges near the screw notch and pull it straight out of its socket.
  17. Lenovo ThinkPad P1 Gen 7 SSD Replacement, Thermal pad information: 手順 17、 3の画像 1 Lenovo ThinkPad P1 Gen 7 SSD Replacement, Thermal pad information: 手順 17、 3の画像 2 Lenovo ThinkPad P1 Gen 7 SSD Replacement, Thermal pad information: 手順 17、 3の画像 3
    • Check the condition of the two thermal pads under the SSD and replace them if they're damaged. If a pad remained intact on the bottom of the old SSD, carefully transfer it to its spot on the board.
    • If you're changing the type of SSD (single-sided or double-sided), you'll need to change the pads so they're the proper thickness.
    • To replace a damaged pad:
    • Make sure your new pad is the correct thickness and size. Pad thickness depends on the type of your replacement SSD—2.25 mm for a single-sided SSD and 0.8 mm for a double-sided SSD.
    • Use a spudger or your fingers to carefully remove all of the old pad from the motherboard.
    • Be very careful not to damage any of the small surface-mounted components on the board.
    • Use highly-concentrated (more than 90%) isopropyl alcohol and a lint-free cloth (or coffee filters) to clean up any thermal pad residue.
    • Carefully put the new pad onto the board, making sure it goes into the rectangle marked PAD AREA.
終わりに
ある他の人がこのガイドを完成しました。
Spencer Day
メンバー登録日: 09/14/22
95,787 ポイント
662のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,619のガイドは作成済み
コメント 1 件
Thanks, good piece. It looks like you are installing the SSD in the second slot. And the text mentions that we should check for a thermal pad in the SSD cover. Is there a thermal pad in that cover when it has not been used before? I will install a Samsung 990 Pro 1 TB drive there and I'd like to know what thermal pads to acquire for this.
arlo247 - 返信
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 47
過去 30 日: 160
今までの合計 1,114
