メインコンテンツにスキップ
Lenovo IdeaPad Flex 5-1570 USB Port Replacement
必要な工具と部品
  1. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Back Panel: 手順 1、 2の画像 1 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Back Panel: 手順 1、 2の画像 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 2、 3の画像 1 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 2、 3の画像 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 2、 3の画像 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 3、 2の画像 1 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 3、 2の画像 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Fan: 手順 4、 1の画像 1
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  5. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 5、 1の画像 1
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  6. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 6、 2の画像 1 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 6、 2の画像 2
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
  7. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Battery: 手順 7、 2の画像 1 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Battery: 手順 7、 2の画像 2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  8. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 8、 3の画像 1 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 8、 3の画像 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 8、 3の画像 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  9. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Speakers: 手順 9、 3の画像 1 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Speakers: 手順 9、 3の画像 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Speakers: 手順 9、 3の画像 3
    • Using the iFixit nylon tipped tweezers, disconnect the wire that connects the speakers to the motherboard.
  10. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 10、 2の画像 1 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 10、 2の画像 2
    • Using your hands, gently pull the left speaker up and out of the device.
  11. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 11、 2の画像 1 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 11、 2の画像 2
    • Repeat the previous step for the other speaker and remove the speakers from the device.
  12. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Motherboard: 手順 12、 1の画像 1
    • Using the Phillips #00 screwdriver, remove the three 5 mm Phillips #00 screws securing the motherboard.
  13. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 13、 2の画像 1 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 13、 2の画像 2
    • Disconnect the auxiliary port cable from the motherboard.
  14. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 14、 3の画像 1 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 14、 3の画像 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 14、 3の画像 3
    • Using a plastic opening tool, unlock the four ZIF connectors of the flat cables.
    • Lift up the connector locking tab and disconnect the cables from the motherboard.
  15. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 15、 2の画像 1 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 15、 2の画像 2
    • Disconnect the display cable from the motherboard.
  16. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 16、 2の画像 1 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 16、 2の画像 2
    • Using the plastic opening tool, unlock the connector for the side ports panel and disconnect the cable from the motherboard.
  17. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 17、 2の画像 1 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: 手順 17、 2の画像 2
    • Carefully lift and remove the motherboard from the device.
  18. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, USB Port: 手順 18、 1の画像 1
    • Once you've removed the motherboard, desolder the four contact points on the USB connector.
    • For proper technique on soldering and desoldering connections, please visit the How to Solder and Desolder Connections guide.
    • Remove the USB port from the device.
    • Resolder the new USB connector in the same place.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Nate Blake
メンバー登録日: 01/23/20
507 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S2-G6, White Winter 2020 Cal Poly, Team S2-G6, White Winter 2020人のメンバー
CPSU-WHITE-W20S2G6
4 メンバー
13のガイドは作成済み
2 件のコメント
what is the replacement part number?
Edwin Maynard - 返信
Was anyone able to find a part number for the specific USB ports?
Greg - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 37
今までの合計 2,814
