メインコンテンツにスキップ
Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement
必要な工具と部品
  1. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Back Panel: 手順 1、 2の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Back Panel: 手順 1、 2の画像 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 2、 3の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 2、 3の画像 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 2、 3の画像 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 3、 2の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 3、 2の画像 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Battery: 手順 4、 2の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Battery: 手順 4、 2の画像 2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 5、 3の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 5、 3の画像 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 5、 3の画像 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Hard Drive: 手順 6、 1の画像 1
    • Remove the three 5 mm Phillips #00 screws that secure the hard drive.
  7. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 7、 2の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 7、 2の画像 2
    • Using your hands, gently pull the hard drive back, sliding it out from the port.
  8. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Fan: 手順 8、 1の画像 1
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  9. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 9、 1の画像 1
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  10. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 10、 2の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 10、 2の画像 2
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
  11. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Heatsink: 手順 11、 1の画像 1
  12. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 12、 2の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 12、 2の画像 2
    • Carefully remove the heatsink from the device.
    • During reassembly, don't forget to apply thermal paste onto the heatsink. For proper technique on thermal paste application, please visit the How to Apply Thermal Paste guide.
  13. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Speakers: 手順 13、 3の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Speakers: 手順 13、 3の画像 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Speakers: 手順 13、 3の画像 3
    この手順で使用する道具:
    購入する
    • Using the iFixit nylon tipped tweezers, disconnect the wire that connects the speakers to the motherboard.
  14. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 14、 2の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 14、 2の画像 2
    • Using your hands, gently pull the left speaker up and out of the device.
  15. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 15、 2の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 15、 2の画像 2
    • Repeat the previous step for the other speaker and remove the speakers from the device.
  16. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Motherboard: 手順 16、 1の画像 1
    • Using the Phillips #00 screwdriver, remove the three 5 mm Phillips #00 screws securing the motherboard.
  17. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 17、 2の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 17、 2の画像 2
    • Disconnect the auxiliary port cable from the motherboard.
  18. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 18、 3の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 18、 3の画像 2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 18、 3の画像 3
    • Using a plastic opening tool, unlock the four ZIF connectors of the flat cables.
    • Lift up the connector locking tab and disconnect the cables from the motherboard.
  19. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 19、 2の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 19、 2の画像 2
    • Disconnect the display cable from the motherboard.
  20. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 20、 2の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 20、 2の画像 2
    • Using the plastic opening tool, unlock the connector for the side ports panel and disconnect the cable from the motherboard.
  21. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 21、 2の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 21、 2の画像 2
    • Carefully lift and remove the motherboard from the device.
  22. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Display Assembly: 手順 22、 2の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Display Assembly: 手順 22、 2の画像 2
    • Using the Phillips #00 screwdriver, remove the four total 5 mm screws from the left and right hinges (two screws on each hinge).
    • For proper screwdriver technique, please visit the Screwdriver Best Practices guide.
  23. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 23、 2の画像 1 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 手順 23、 2の画像 2
    • Disconnect the display assembly from the rest of the device.
終わりに
作成者
1人の作成者と共同作成されました。
Justin Ogihara
メンバー登録日: 09/18/17
27,662 ポイント
52のガイドは作成済み
チーム
EDU Team EDU Team人のメンバー
Staff
7 メンバー
677のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 82
今までの合計 4,563
