メインコンテンツにスキップ
Lenovo IdeaPad 120s-14IAP Battery Replacement
必要な工具と部品
  1. Lenovo IdeaPad 120s-14IAP Battery Replacement, Back Cover: 手順 1、 1の画像 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so the top is laying flat on your work surface.
    • Remove ten 1.5mm Torx T5 screws from the back of the laptop.
  2. Lenovo IdeaPad 120s-14IAP Battery Replacement: 手順 2、 1の画像 1
    • Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
    • Remove the back cover.
  3. Lenovo IdeaPad 120s-14IAP Battery Replacement, Battery: 手順 3、 1の画像 1
    • Remove five 1.5mm Phillips screws from the battery edges.
    We found that a Phillips 00 head works for this step/
    Kyle P Sumpter - 返信
  4. Lenovo IdeaPad 120s-14IAP Battery Replacement: 手順 4、 1の画像 1
    • Use your fingers or a spudger to unlock the wide ribbon cable's ZIF connector.
    • To unlock a ZIF connector, flip up the small, hinged locking flap.
    • Gently pull the connector from the battery side until it is fully detached from the daughterboard.
  5. Lenovo IdeaPad 120s-14IAP Battery Replacement: 手順 5、 1の画像 1
    • Gently pull the power harness away from the daughterboard until the connector is detached.
    • Pull parallel to the board, not straight up.
  6. Lenovo IdeaPad 120s-14IAP Battery Replacement: 手順 6、 1の画像 1
    • With the laptop oriented so that the long edge faces you and the battery is closest to you, carefully remove the battery by lifting on the longitudinal edge.
    • Pull the battery directly towards you and out from under the forward retaining strap.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Kyle P Sumpter
メンバー登録日: 09/17/19
363 ポイント
2のガイドは作成済み
チーム
2 件のコメント
Thank you for showing exactly how to remove the battery connections, thanks!
Erik Gunnar Gervin - 返信
Great guide. I may well need a new battery but would appreciate your comment. Battery shows charging but never gets above 0%
When I put a meter at the 2 red cables they show zero volts (even when computer on, and showing charging). Other wires are ~1.6v & 3.4v.
Could I have a faulty battery or something else?
Colin Kinsella - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 38
今までの合計 5,154
