メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Lenovo Essential B570 Keyboard Replacement
必要な工具と部品
  1. Lenovo Essential B570 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Turn over laptop.
    • Switch open the left battery lock.
    • If you are replacing inner components of the laptop, it is recommended to remove the battery first to avoid damage to the laptop.
    FixBotに聞いてみる
    コメントを追加
  2. Lenovo Essential B570 Keyboard Replacement: 手順 2、 1の画像 1
    • Hold the right battery lock open with one hand while removing the battery itself with the other.
    FixBotに聞いてみる
    コメントを追加
  3. Lenovo Essential B570 Keyboard Replacement, Back Panel: 手順 3、 1の画像 1
    • Loosen the five Philips screws that secure the panel.
    • The screws do not actually fully remove from the panel. Loosening them as much as you can will be enough to disconnect them from the laptop.
    FixBotに聞いてみる
    コメントを追加
  4. Lenovo Essential B570 Keyboard Replacement: 手順 4、 3の画像 1 Lenovo Essential B570 Keyboard Replacement: 手順 4、 3の画像 2 Lenovo Essential B570 Keyboard Replacement: 手順 4、 3の画像 3
    • Prop open the cover with a plastic opening tool.
    • If the cover does not come off easily, do not force it. Make sure all screws are loosened.
    FixBotに聞いてみる
    コメントを追加
  5. Lenovo Essential B570 Keyboard Replacement, Keyboard: 手順 5、 1の画像 1
    • Remove the three 3 mm Phillips screws holding the keyboard in. These screws are designated by an imprinted keyboard picture next to them.
    FixBotに聞いてみる
    コメントを追加
  6. Lenovo Essential B570 Keyboard Replacement: 手順 6、 2の画像 1 Lenovo Essential B570 Keyboard Replacement: 手順 6、 2の画像 2
    • Carefully pry off the keyboard with your plastic opening tool , moving along the edges.
    • DO NOT immediately remove the keyboard as it is still connected underneath by a wire.
    FixBotに聞いてみる
    コメントを追加
  7. Lenovo Essential B570 Keyboard Replacement: 手順 7、 2の画像 1 Lenovo Essential B570 Keyboard Replacement: 手順 7、 2の画像 2
    • Carefully lift the keyboard.
    • The keyboard is still connected to the laptop. Lift it slowly.
    • Turn over the keyboard to locate the keyboards ribbon cable.
    FixBotに聞いてみる
    コメントを追加
  8. Lenovo Essential B570 Keyboard Replacement: 手順 8、 2の画像 1 Lenovo Essential B570 Keyboard Replacement: 手順 8、 2の画像 2
    • Use the plastic opening tool to lift open the ribbon connector that is holding the ribbon cable in its slot.
    FixBotに聞いてみる
    コメントを追加
  9. Lenovo Essential B570 Keyboard Replacement: 手順 9、 2の画像 1 Lenovo Essential B570 Keyboard Replacement: 手順 9、 2の画像 2
    • Remove the cable from its slot.
    • If the cable does not come out easily, ensure that the black ribbon has been completely released.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Samuel Filliettaz
メンバー登録日: 10/20/15
891 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 4-5, Catania Fall 2015 UMass Dartmouth, Team 4-5, Catania Fall 2015人のメンバー
UMASSD-CATANIA-F15S4G5
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 26
今までの合計 3,096
