はじめに
This guide will teach you to replace the LCD screen of your laptop computer.
必要な工具と部品
Remove the black plastic or rubber screw caps covering screws, located at the bottom of the screen
7 の人々がこのガイドを完成させました。
5件のガイドコメント
Does the lcd separate from the digitizer screen or do both need to be replaced if the digitizer is cracked?
Sylvia Gagne - 返信 共有
Typically one can separate the LCD from the glass, but it is a difficult and painful process, and it almost always cracks the LCD. If the cost is not prohibitively expensive, I would just replace them together as one unit.
Allan Wilson - 返信 共有
I need that exact bottom frame strip piece replaced that they are showing in the first picture. Does anyone know where I can order one?
looking to replace the whole screen, if possible even the hinge.
nasty bent screen I have for over 2+ years and I want to change that. Any advice welcomed.
frame is bent, Glass is broken in corner, touch screen gone.
Wouldnt care to install digitizer back but if I can see how to install screen components that be good.
Carry on.
que tal joven talvez usted consiguió la pantalla y en que precio por que también tengo el mismo problema quiero cambiar toda la pantalla.
ToplayVid :v - 返信 共有
