メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Lefant M210 Battery Replacement
必要な工具と部品
    1. Lefant M210 Battery Replacement, Brush: 手順 1、 2の画像 1 Lefant M210 Battery Replacement, Brush: 手順 1、 2の画像 2
      • Turn off the Lefant M210 and disconnect it from the charging dock.
      • Flip the unit over so the bottom faces upward.
      • Locate the circular brush assemblies on the left and right sides of the underside.
      • Place the unit on a clean, flat surface to prevent scratching.
      FixBotに聞いてみる
      コメントを追加
    2. Lefant M210 Battery Replacement: 手順 2、 3の画像 1 Lefant M210 Battery Replacement: 手順 2、 3の画像 2 Lefant M210 Battery Replacement: 手順 2、 3の画像 3
      • Insert the iFixit Opening Tool (or similar pry tool) under the circular edge of the brush assembly.
      • Apply gentle downward pressure on the opposite end of the tool to lever the brush component out of its housing.
      • Remove the brush assembly completely and set it aside.
      • If replacing both brush assemblies, repeat this process on the other side.
      • Avoid using excessive force, which may damage the mounting clips.
      FixBotに聞いてみる
      コメントを追加
      • Position the new brush assembly above the square mounting peg.
      • Align the square cavity on the bottom of the brush with the corresponding square peg in the vacuum housing.
      • Press down firmly on the brush assembly until you hear or feel it click into place.
      • Gently tug on the brush to verify it is securely seated.
      • The brush should sit flush with the housing and not move when pulled gently.
      FixBotに聞いてみる
      コメントを追加
    1. Lefant M210 Battery Replacement, Wheel Assembly: 手順 4、 1の画像 1
      • Use a Phillips screwdriver to remove four screws near each wheel.
      FixBotに聞いてみる
      コメントを追加
    2. Lefant M210 Battery Replacement: 手順 5、 2の画像 1 Lefant M210 Battery Replacement: 手順 5、 2の画像 2
      • Remove the plastic cover next to each wheel.
      • Grip both sides of the wheel and pull upwards.
      • The wheels of the device require some force to remove.
      • Don't pull the wheels too hard as they are attached to cables and may be damaged if yanked.
      FixBotに聞いてみる
      コメントを追加
    3. Lefant M210 Battery Replacement: 手順 6、 3の画像 1 Lefant M210 Battery Replacement: 手順 6、 3の画像 2 Lefant M210 Battery Replacement: 手順 6、 3の画像 3
      • Hold the wheel up and detach the connector to release it from the device.
      FixBotに聞いてみる
      コメントを追加
    1. Lefant M210 Battery Replacement, Dustbin Filters: 手順 7、 1の画像 1
      • Open the dustbin compartment.
      FixBotに聞いてみる
      コメントを追加
    2. Lefant M210 Battery Replacement: 手順 8、 2の画像 1 Lefant M210 Battery Replacement: 手順 8、 2の画像 2
      • With your hands, gently pull the dustbin to remove it from its compartment.
      FixBotに聞いてみる
      コメントを追加
    3. Lefant M210 Battery Replacement: 手順 9、 1の画像 1
      • With your hands, pull off the filter compartment from the dustbin.
      FixBotに聞いてみる
      コメントを追加
    4. Lefant M210 Battery Replacement: 手順 10、 1の画像 1
      • Pull off the filter from the filter compartment.
      FixBotに聞いてみる
      コメントを追加
    1. Lefant M210 Battery Replacement, Battery: 手順 11、 1の画像 1
      • Use a Phillips #1 screwdriver to remove the six screws around the bottom edge of the device.
      FixBotに聞いてみる
      コメントを追加
    2. Lefant M210 Battery Replacement: 手順 12、 2の画像 1 Lefant M210 Battery Replacement: 手順 12、 2の画像 2
      • Carefully flip the vacuum back right-side-up, making sure you're holding it all together so that the bottom portion doesn't fall out.
      • Rotate the vacuum so that the Lefant logo is facing you.
      • Carefully lift the white cover of the vacuum, opening it like a laptop, from front to back.
      • Rest the open cover something stable, like a wall.
      FixBotに聞いてみる
      コメントを追加
    3. Lefant M210 Battery Replacement: 手順 13、 2の画像 1 Lefant M210 Battery Replacement: 手順 13、 2の画像 2
      • Use a Phillips #1 screwdriver to remove the three screws securing the motherboard to the device.
      FixBotに聞いてみる
      コメントを追加
    4. Lefant M210 Battery Replacement: 手順 14、 1の画像 1
      • Carefully lift the motherboard, ensuring you don't rip any cables that are connected to it.
      • The battery should be under the motherboard.
      FixBotに聞いてみる
      コメントを追加
    5. Lefant M210 Battery Replacement: 手順 15、 2の画像 1 Lefant M210 Battery Replacement: 手順 15、 2の画像 2
      • Push the two retaining clips away from the battery while pulling the battery up from the tabs attached to it to free it.
      • Retaining clips
      • Battery tabs
      • Work on freeing one side at a time so that it's easier to free the battery.
      FixBotに聞いてみる
      コメントを追加
    6. Lefant M210 Battery Replacement: 手順 16、 1の画像 1
      • When the battery is free from it's housing, lift it out completely using its pull tabs.
      FixBotに聞いてみる
      コメントを追加
    7. Lefant M210 Battery Replacement: 手順 17、 2の画像 1 Lefant M210 Battery Replacement: 手順 17、 2の画像 2
      • Locate the battery connection wire and carefully pull apart the connection.
      • Pinch the motherboard's wire connector and pull the connection apart.
      • The connection is secured by a clothespin-like mechanism.
      • When you replace your battery with a new one, allow the robot vacuum to fully charge for a few hours before using it again.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Darien Amador
メンバー登録日: 09/09/24
300 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 2-4, Kershman Fall 2024 CSU Los Angeles, Team 2-4, Kershman Fall 2024人のメンバー
CSULA-KERSHMAN-F24S2G4
4 メンバー
13のガイドは作成済み
5件のガイドコメント
Great guide! Any knowledge on how or why mine beeps twice even when it is on the ground?
Jonathan Manuel - 返信 共有
Thank you for the helpful guide, however, after replacing my battery, it definitely has a much shorter lifespan, and it is unable to find the charger before it dies.
Tee Cee - 返信 共有
I thought it was because I needed a new battery. My stops about 1min after start. When I put it back to the charger it indicates battery charged by showing the blue light. Still after 1 min of operation it dies. That's the reason why i want to replace the battery. Is that what yours is doing too even after replacing the battery?
Zed - 返信 共有
Thanks for the guide.
As for those that stumble upon this, mind that ******if you only want to access the battery, steps 10 to 16 are the only on you need.
Sylvain “Neoblasphem” Mourot - 返信 共有
Bought new batt, installed it and same problem. Red light, not charging. I guess it’s dead for good.
Kelly In Cali - 返信 共有
コメントを追加
統計データ:
過去 24時間: 22
過去 7 日: 217
過去 30 日: 888
今までの合計 15,322
