メインコンテンツにスキップ
Lasko CD08200 ACLI Safety Plug and Cable Replacement
必要な工具と部品
  1. Lasko CD08200 ACLI Safety Plug and Cable Replacement, ACLI Safety Plug and Cable: 手順 1、 2の画像 1 Lasko CD08200 ACLI Safety Plug and Cable Replacement, ACLI Safety Plug and Cable: 手順 1、 2の画像 2
    • Please disconnect the device and let it sit for 10 minutes so any fuses can drain before beginning this guide.
    • Turn over the device and place it on its head. Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
  2. Lasko CD08200 ACLI Safety Plug and Cable Replacement: 手順 2、 1の画像 1
    • Remove both 14mm screws from the power cord casing using a Phillips #2 screwdriver.
    • Remove the power cord casing from the device case.
  3. Lasko CD08200 ACLI Safety Plug and Cable Replacement: 手順 3、 2の画像 1 Lasko CD08200 ACLI Safety Plug and Cable Replacement: 手順 3、 2の画像 2
    • Trace the two grey cables of the ACLI plug to their white wire connectors. Pinch the wire connector and pull out the wire connector with pliers.
    • Keep record of which independent wire went to which wire connector.
  4. Lasko CD08200 ACLI Safety Plug and Cable Replacement: 手順 4、 1の画像 1
    • Heat up the end of the wire from the tip of the solder iron.
    • While the wire is still hot, untwist the wires using pliers.
    • If other wires are obstructing each other, you can cut the black zip tie holding together the wires for more room.
    • During reassembly, twist each independent end of wire into each other with pliers until the twisted wire’s end is pointed.
  5. Lasko CD08200 ACLI Safety Plug and Cable Replacement: 手順 5、 3の画像 1 Lasko CD08200 ACLI Safety Plug and Cable Replacement: 手順 5、 3の画像 2 Lasko CD08200 ACLI Safety Plug and Cable Replacement: 手順 5、 3の画像 3
    • Gently free the wire from the power cord casing with a spudger.
    • The cable may be too tight to pull out from the power cord casing. If you struggle to pull the cable out, use the pointed end of a spudger to free the cable from the power cord casing.
    • Pull the ACLI cable out from the power cord casing with your hands.
    • Pull the entire ACLI cable out of the device.
    • During reassembly, do not use a metal spudger to push the cable back into the power cord casing. You might break the cable’s insulation when applying force to the cable with a metal spudger.
終わりに
作成者
1人の作成者と共同作成されました。
Artur Komissarov
メンバー登録日: 01/14/20
382 ポイント
2のガイドは作成済み
チーム
York University, Team S1-G1, Woodhouse Winter 2020 York University, Team S1-G1, Woodhouse Winter 2020人のメンバー
YORK-WOODHOUSE-W20S1G1
3 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 21
今までの合計 1,283
