メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Laptop Ram/Memory Replacement
必要な工具と部品
    1. Laptop Ram/Memory Replacement, RAM door: 手順 1、 3の画像 1 Laptop Ram/Memory Replacement, RAM door: 手順 1、 3の画像 2 Laptop Ram/Memory Replacement, RAM door: 手順 1、 3の画像 3
      • Many laptops have a door for the ram. But often, removing the entire back cover is necessary.
      • Remove screws on Ram door.
      • There is now access to the ram.
      • Remember to always remove or disconnect the battery!
      FixBotに聞いてみる
      コメントを追加
    2. Laptop Ram/Memory Replacement, Releasing the SODIMM: 手順 2、 1の画像 1
      • Push metal tab out of the way. Some laptops have screws instead of tabs.
      FixBotに聞いてみる
      コメントを追加
    3. Laptop Ram/Memory Replacement, Removing the RAM: 手順 3、 3の画像 1 Laptop Ram/Memory Replacement, Removing the RAM: 手順 3、 3の画像 2 Laptop Ram/Memory Replacement, Removing the RAM: 手順 3、 3の画像 3
      • lift up on ram.
      • Pull out of SODIMM socket.
      FixBotに聞いてみる
      コメントを追加
    4. Laptop Ram/Memory Replacement, Removing second stick: 手順 4、 1の画像 1
      • Repeat with second stick. Sometimes the second stick is layered under the first.
      FixBotに聞いてみる
      コメントを追加
    5. Laptop Ram/Memory Replacement, Replacing the RAM: 手順 5、 1の画像 1
      • Remember, If only replacing one Stick, to put that stick in DIMM A or DIMM 1.
      • There are five types of laptop laptop ram: DDR, DDR2, DDR3, DDR3L, and DDR4.
      • Make sure that whatever ram your laptop was using is replaced by that same type. Memory is not cross compatible with desktop memory, so make sure that your RAM is SODIMM laptop memory. SODIMMs are usually about 3" long, while desktop DIMMs are about 4"-5" long.
      FixBotに聞いてみる
      コメントを追加
    6. Laptop Ram/Memory Replacement, Putting the Memory Back: 手順 6、 3の画像 1 Laptop Ram/Memory Replacement, Putting the Memory Back: 手順 6、 3の画像 2 Laptop Ram/Memory Replacement, Putting the Memory Back: 手順 6、 3の画像 3
      • Re-insert RAM at a 45 degree angle and push down until clips snap into place or screw back in.
      • Make sure that pins line up correctly and memory is all the way in place.
      • This is incorrect.
      • Replace RAM door.
      FixBotに聞いてみる
      コメントを追加
ゴール
キャンセル: このガイドを終了できませんでした。
24 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
George A.
メンバー登録日: 12/07/16
22,563 ポイント
4のガイドは作成済み
4件のガイドコメント
Thank you! Your photographs and simple directions gave me the courage to try this. It’s kind of exhilarating to see those memory sticks pop up and then to hear them click in.
Christie Sonmez - 返信 共有
@curiousandcheap I'm glad I could help! It's really one of the simplest upgrades you can do as long as your laptop doesn't specifically block access to the RAM compartment, but most brands make a door like the one shown to make it easier.
George A. - 返信 共有
merci beaucoup pour ces tutoriels sa n
ma beaucoup aider
abdoul kader - 返信 共有
very interested with demostrations,easy and understood
WAZIRI KIBULA - 返信 共有
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 95
過去 30 日: 479
今までの合計 38,973
