メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG Vortex Screen Replacement
必要な工具と部品
  1. LG Vortex Screen Replacement, Power down the Phone: 手順 1、 1の画像 1
    • Power the phone off
    • The power button is located on top of the phone
    FixBotに聞いてみる
    コメントを追加
  2. LG Vortex Screen Replacement, Remove the Back Cover: 手順 2、 3の画像 1 LG Vortex Screen Replacement, Remove the Back Cover: 手順 2、 3の画像 2 LG Vortex Screen Replacement, Remove the Back Cover: 手順 2、 3の画像 3
    • Find the two thumbnail ridges on the side and top of the phone. One is next to the micro SD slot and the other at the top of the phone
    • Once the ridges are located, use the blue plastic opening tool to pry the back cover away from the rest of the phone.
    • Remove the back cover and set it to the side.
    FixBotに聞いてみる
    コメントを追加
  3. LG Vortex Screen Replacement: 手順 3、 1の画像 1
    • Remove the battery using the blue plastic opening tool.
    • There is a small thumbnail ridge at the top left corner of the battery for ease of removal.
    • Put the battery aside.
    FixBotに聞いてみる
    コメントを追加
  4. LG Vortex Screen Replacement, Unscrew the Back Frame: 手順 4、 2の画像 1 LG Vortex Screen Replacement, Unscrew the Back Frame: 手順 4、 2の画像 2
    • All screws are the same size screwdriver head #00
    • Use the precision screwdriver to remove the 6 screws along the edges of the phone.
    • There are 2 screws at the top in each corner, 2 in the middle on the sides, and 2 in the bottom corners.
    • Place the screws in a container to ensure they aren't lost.
    FixBotに聞いてみる
    コメントを追加
  5. LG Vortex Screen Replacement, Remove the Back Frame: 手順 5、 3の画像 1 LG Vortex Screen Replacement, Remove the Back Frame: 手順 5、 3の画像 2 LG Vortex Screen Replacement, Remove the Back Frame: 手順 5、 3の画像 3
    • Use the blue plastic opening tool to remove the back frame from the rest of the phone.
    • Pry at the micro SD slot. Push the cover for the SD slot away from the front of the phone and pry the back frame away from the rest of the phone.
    • Pry your way around the entire phone to separate the face from the frame.
    FixBotに聞いてみる
    コメントを追加
  6. LG Vortex Screen Replacement, Screen: 手順 6、 3の画像 1 LG Vortex Screen Replacement, Screen: 手順 6、 3の画像 2 LG Vortex Screen Replacement, Screen: 手順 6、 3の画像 3
    • Unclip the screen connector that is connecting the screen to the system board. It is on the right side of the phone, and looks like a thin piece of bronze plastic.
    • Be gentle.
    FixBotに聞いてみる
    コメントを追加
  7. LG Vortex Screen Replacement: 手順 7、 3の画像 1 LG Vortex Screen Replacement: 手順 7、 3の画像 2 LG Vortex Screen Replacement: 手順 7、 3の画像 3
    • Pull the volume button away from the case and set aside. It is located on the left side of the phone, and is held to the frame by a small nub.
    FixBotに聞いてみる
    コメントを追加
  8. LG Vortex Screen Replacement: 手順 8、 1の画像 1
    • Pull the white piece underneath the volume button away from the frame.
    FixBotに聞いてみる
    コメントを追加
  9. LG Vortex Screen Replacement: 手順 9、 2の画像 1 LG Vortex Screen Replacement: 手順 9、 2の画像 2
    • Unscrew the two short black screws at the bottom of the phone, which are holding the USB port to the frame.
    • Place the screws in a safe place
    FixBotに聞いてみる
    コメントを追加
  10. LG Vortex Screen Replacement: 手順 10、 3の画像 1 LG Vortex Screen Replacement: 手順 10、 3の画像 2 LG Vortex Screen Replacement: 手順 10、 3の画像 3
    • Lift the system board up and away from the front screen
    • Caution! Perform this step slowly, because the two pieces will still be attached at the top of the phone.
    FixBotに聞いてみる
    コメントを追加
  11. LG Vortex Screen Replacement: 手順 11、 3の画像 1 LG Vortex Screen Replacement: 手順 11、 3の画像 2 LG Vortex Screen Replacement: 手順 11、 3の画像 3
    • Loosen the screen from the frame at one of four corners using a flat head screwdriver.
    • Look for small rectangle holes and use these to pry the LCD screen away from the face of the phone (the frame).
    • Remove the LCD screen.
    • Be sure not to touch or contaminate the LCD or the clear face with dust or your hands.
    FixBotに聞いてみる
    コメントを追加
    • Install new screen.
    • Important: Be extremely careful not to get the front screen or clear plastic face dirty- dust will affect the usability.
    FixBotに聞いてみる
    コメントを追加
  12. LG Vortex Screen Replacement: 手順 13、 1の画像 1
    • Reverse the steps to reassemble the phone.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
7人の作成者と共同で作成されました。
Jen
メンバー登録日: 02/13/14
40 ポイント
3のガイドは作成済み
チーム
Ohio State, Team 1-3, Buehl Spring 2014 Ohio State, Team 1-3, Buehl Spring 2014人のメンバー
OSU-BUEHL-S14S1G3
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 34
今までの合計 3,356
