この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Use this guide to replace the secondary rear-facing camera of your LG V20.
必要な工具と部品
Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
Be careful not to deform or puncture the battery.
Pry up and remove the battery.
Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
Use an iOpener to loosen the adhesive beneath the secondary rear facing camera.
ある他の人がこのガイドを完成しました。
