メインコンテンツにスキップ
LG Refrigerator Freezer Drawer Slide Replacement
必要な工具と部品
  1. LG Refrigerator Freezer Drawer Slide Replacement, Unplug your refrigerator: 手順 1、 1の画像 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. LG Refrigerator Freezer Drawer Slide Replacement, Open the freezer door: 手順 2、 2の画像 1 LG Refrigerator Freezer Drawer Slide Replacement, Open the freezer door: 手順 2、 2の画像 2
    • Pull open the freezer door fully.
  3. LG Refrigerator Freezer Drawer Slide Replacement, Remove the drawer and bin: 手順 3、 3の画像 1 LG Refrigerator Freezer Drawer Slide Replacement, Remove the drawer and bin: 手順 3、 3の画像 2 LG Refrigerator Freezer Drawer Slide Replacement, Remove the drawer and bin: 手順 3、 3の画像 3
    • Lift and remove the upper pull-out drawer.
    • Lift and remove the main drawer bin.
  4. LG Refrigerator Freezer Drawer Slide Replacement, Remove the drawer rail covers: 手順 4、 3の画像 1 LG Refrigerator Freezer Drawer Slide Replacement, Remove the drawer rail covers: 手順 4、 3の画像 2 LG Refrigerator Freezer Drawer Slide Replacement, Remove the drawer rail covers: 手順 4、 3の画像 3
    • Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
    • Lift the cover off of the rail and remove it.
    • Repeat this procedure for the left drawer rail cover.
  5. LG Refrigerator Freezer Drawer Slide Replacement, Reassembly notes: 手順 5、 2の画像 1 LG Refrigerator Freezer Drawer Slide Replacement, Reassembly notes: 手順 5、 2の画像 2
    • The drawer rail covers can be tricky to reinstall. Follow these steps to reinstall them:
    • Hold the drawer rail cover flush against the side of the drawer rail.
    • You should feel the locking tabs protruding.
    • Push the rail cover straight downward to install. It should click into place.
  6. LG Refrigerator Freezer Drawer Slide Replacement, Remove the drawer: 手順 6、 2の画像 1 LG Refrigerator Freezer Drawer Slide Replacement, Remove the drawer: 手順 6、 2の画像 2
    • Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
  7. LG Refrigerator Freezer Drawer Slide Replacement: 手順 7、 3の画像 1 LG Refrigerator Freezer Drawer Slide Replacement: 手順 7、 3の画像 2 LG Refrigerator Freezer Drawer Slide Replacement: 手順 7、 3の画像 3
    • Lift the front of the drawer up.
    • Pull the drawer toward you to release the drawer from the drawer slides.
    • Remove the freezer drawer.
  8. LG Refrigerator Freezer Drawer Slide Replacement, Release the drawer slides: 手順 8、 1の画像 1
    • Use a Phillips screwdriver to remove the screws securing both left drawer slides.
  9. LG Refrigerator Freezer Drawer Slide Replacement, Remove the upper left drawer slide: 手順 9、 2の画像 1 LG Refrigerator Freezer Drawer Slide Replacement, Remove the upper left drawer slide: 手順 9、 2の画像 2
    • Pull the upper left drawer slide slightly towards you to release the locking tab at the rear.
    • Remove the upper left drawer slide.
  10. LG Refrigerator Freezer Drawer Slide Replacement, Release lower left drawer slide and reposition it: 手順 10、 3の画像 1 LG Refrigerator Freezer Drawer Slide Replacement, Release lower left drawer slide and reposition it: 手順 10、 3の画像 2 LG Refrigerator Freezer Drawer Slide Replacement, Release lower left drawer slide and reposition it: 手順 10、 3の画像 3
    • Pull the lower left drawer slide slightly toward you to release the locking tab at the rear.
    • Reposition the lower left drawer slide to gain access to the door switch connector.
  11. LG Refrigerator Freezer Drawer Slide Replacement, Disconnect the drawer switch and remove the lower slide: 手順 11、 3の画像 1 LG Refrigerator Freezer Drawer Slide Replacement, Disconnect the drawer switch and remove the lower slide: 手順 11、 3の画像 2 LG Refrigerator Freezer Drawer Slide Replacement, Disconnect the drawer switch and remove the lower slide: 手順 11、 3の画像 3
    • Squeeze the door switch connector to release it.
    • Pull the door switch connector down to disconnect it.
    • Remove the lower left drawer slide.
    • If you are removing the freezer evaporator cover, likely only the left-hand slides may need to be removed. In some cases you will need to repeat the previous three steps to remove the right slides as well.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
ある他の人がこのガイドを完成しました。
Bill Gilbert
メンバー登録日: 06/30/22
38,497 ポイント
261のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,623のガイドは作成済み
3件のガイドコメント
My drawer won't open fully. It seems to be the left side track is stuck stopping it from opening.
Tresa F Malone - 返信
Tresa F Malone - just now Edit Delete
Tresa F Malone - 返信
La corredera izquierda de mi frigorífico solo corre hasta la mitad
Raul Padilla - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 38
過去 30 日: 184
今までの合計 3,505
