メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG Optimus T Button Replacement
必要な工具と部品
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Using a prying device, such as a Spudger, remove the phone's back cover. At the top of the phone, there's an indentation to put the Spudger into to pop the case off.
    FixBotに聞いてみる
    コメントを追加
  1. LG Optimus T Button Replacement: 手順 2、 1の画像 1
    • Remove the battery. There's an indentation to the left of the camera lens to pull up on the battery with your finger.
    FixBotに聞いてみる
    コメントを追加
  2. LG Optimus T Button Replacement: 手順 3、 1の画像 1
    • Use a J0 screwdriver to remove the six 4.5 mm screws.
    FixBotに聞いてみる
    コメントを追加
  3. LG Optimus T Button Replacement: 手順 4、 2の画像 1 LG Optimus T Button Replacement: 手順 4、 2の画像 2
    • Remove interior case. Insert the spudger into the indentations at the top or bottom of the phone to pry off the interior case.
    • You might have difficulty popping the case off. You may use the metal spudger if the plastic one fails. Be cautious when using it, as the metal spudger may damage your phone.
    FixBotに聞いてみる
    コメントを追加
  4. LG Optimus T Button Replacement: 手順 5、 3の画像 1 LG Optimus T Button Replacement: 手順 5、 3の画像 2 LG Optimus T Button Replacement: 手順 5、 3の画像 3
    • Remove power button found on top of the phone.
    • Remove the volume button found on the side of the phone.
    • There is an indentation that has been marked near the edge that part of the volume button inserts in to. You will use this when reassembling your phone.
    • When reassembling your phone, place buttons on the metal nodes that have been marked.
    FixBotに聞いてみる
    コメントを追加
  5. LG Optimus T Button Replacement: 手順 6、 1の画像 1
    • Pull up on connector tab.
    FixBotに聞いてみる
    コメントを追加
  6. LG Optimus T Button Replacement: 手順 7、 2の画像 1 LG Optimus T Button Replacement: 手順 7、 2の画像 2
    • Remove SD card mount. Insert a plastic opening tool on the right side to pop off.
    FixBotに聞いてみる
    コメントを追加
  7. LG Optimus T Button Replacement: 手順 8、 2の画像 1 LG Optimus T Button Replacement: 手順 8、 2の画像 2
    • There are 4 retaining points to insert a plastic opening tool into and pop off panel.
    FixBotに聞いてみる
    コメントを追加
  8. LG Optimus T Button Replacement: 手順 9、 1の画像 1
    • Remove 2 black J0 Phillip's head 1.8 mm screws from charging port.
    • Charging port and motherboard are connected.
    • Remove motherboard.
    FixBotに聞いてみる
    コメントを追加
  9. LG Optimus T Button Replacement: 手順 10、 2の画像 1 LG Optimus T Button Replacement: 手順 10、 2の画像 2
    • Pop off home buttons.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Patrick Esguerra
メンバー登録日: 02/07/17
126 ポイント
1ガイドが承認済み
チーム
Ohio State, Team 1-3, Wilder Spring 2017 Ohio State, Team 1-3, Wilder Spring 2017人のメンバー
OSU-WILDER-S17S1G3
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 29
今までの合計 433
