メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG Optimus F3 Charging port unit Replacement
必要な工具と部品
    1. LG Optimus F3 Charging port unit  Replacement, Motherboard: 手順 1、 1の画像 1
      • Turn the device so that the back faces up.
      • It is easiest to open the case near the charging port located at the bottom of the phone.
      • Remove the back case by pushing up on the back and pulling down on the face as illustrated in the image.
      FixBotに聞いてみる
      コメントを追加
    2. LG Optimus F3 Charging port unit  Replacement: 手順 2、 1の画像 1
      • With back case removed, the battery is visible. The battery is the large square object.
      • Remove the battery by flipping the bottom edge upward to separate the battery from the case.
      FixBotに聞いてみる
      コメントを追加
    3. LG Optimus F3 Charging port unit  Replacement: 手順 3、 1の画像 1
      • Remove 10 1.0 mm screws located on the back of the device.
      • Refer to the outlined locations in the image for the screws.
      FixBotに聞いてみる
      コメントを追加
    4. LG Optimus F3 Charging port unit  Replacement: 手順 4、 1の画像 1
      • Use the plastic opening tool to separate the inner case from the device.
      • Wedge the plastic opening tool between the case.
      • Wiggle the tool and use leverage to pry the case apart.
      FixBotに聞いてみる
      コメントを追加
    5. LG Optimus F3 Charging port unit  Replacement: 手順 5、 1の画像 1
      • The camera unit is located at the top left of the phone. The camera is a silver box with a black lens. The image pin points where the camera is on the motherboard.
      • Use the plastic opening tool to separate the camera from the motherboard.
      • Wedge the plastic tool between the camera and the motherboard to loosen the camera unit.
      FixBotに聞いてみる
      コメントを追加
    6. LG Optimus F3 Charging port unit  Replacement: 手順 6、 1の画像 1
      この手順で使用する道具:
      • Use a pair of tweezers to disconnect and remove the rear facing camera.
      FixBotに聞いてみる
      コメントを追加
    7. LG Optimus F3 Charging port unit  Replacement: 手順 7、 1の画像 1
      • Use the plastic opening tool to separate the sim card and the memory card connector from the motherboard.
      • Note that the sim card and the memory card connector are one unit.
      • Wedge the plastic tool to lift up the sim-memory unit from the motherboard.
      FixBotに聞いてみる
      コメントを追加
    8. LG Optimus F3 Charging port unit  Replacement: 手順 8、 1の画像 1
      • Use the plastic opening tool to remove the charging port unit.
      • Wedge the plastic opening tool between the charging port unit and the motherboard to separate the port.
      FixBotに聞いてみる
      コメントを追加
    9. LG Optimus F3 Charging port unit  Replacement: 手順 9、 1の画像 1
      • Use the plastic opening tool to remove the motherboard located directly above the battery encasement.
      • The motherboard is an L-shaped unit above and to the left of the battery encasement.
      • Wedge the plastic opening tool between the circuit board and the motherboard to separate the unit.
      FixBotに聞いてみる
      コメントを追加
    1. LG Optimus F3 Charging port unit  Replacement, Charging port unit: 手順 10、 1の画像 1
      • Remove one 1.0 mm screw.
      FixBotに聞いてみる
      コメントを追加
    2. LG Optimus F3 Charging port unit  Replacement: 手順 11、 1の画像 1
      • Use a plastic opening tool to remove front glass protector.
      FixBotに聞いてみる
      コメントを追加
    3. LG Optimus F3 Charging port unit  Replacement: 手順 12、 1の画像 1
      • Use the plastic opening tool to remove front glass cover carefully. Try not to break the connector.
      FixBotに聞いてみる
      コメントを追加
    4. LG Optimus F3 Charging port unit  Replacement: 手順 13、 1の画像 1
      • Remove the front facing camera.
      FixBotに聞いてみる
      コメントを追加
    5. LG Optimus F3 Charging port unit  Replacement: 手順 14、 1の画像 1
      • Use the plastic opening tool to carefully remove the home button board. It is attached with double-sided tape.
      FixBotに聞いてみる
      コメントを追加
    6. LG Optimus F3 Charging port unit  Replacement: 手順 15、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
    7. LG Optimus F3 Charging port unit  Replacement: 手順 16、 1の画像 1
      • You are all set.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jonathan Fang
メンバー登録日: 10/28/15
356 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-5, Miles Fall 2015 UMass Dartmouth, Team 1-5, Miles Fall 2015人のメンバー
UMASSD-MILES-F15S1G5
3 メンバー
20のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 33
過去 30 日: 52
今までの合計 969
