メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG Chocolate Sliding Mechanism Replacement
必要な工具と部品
  1. LG Chocolate Sliding Mechanism Replacement, Battery: 手順 1、 2の画像 1 LG Chocolate Sliding Mechanism Replacement, Battery: 手順 1、 2の画像 2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
    FixBotに聞いてみる
    コメントを追加
  2. LG Chocolate Sliding Mechanism Replacement, Back Cover: 手順 2、 1の画像 1
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
    FixBotに聞いてみる
    コメントを追加
  3. LG Chocolate Sliding Mechanism Replacement: 手順 3、 3の画像 1 LG Chocolate Sliding Mechanism Replacement: 手順 3、 3の画像 2 LG Chocolate Sliding Mechanism Replacement: 手順 3、 3の画像 3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case.
    FixBotに聞いてみる
    コメントを追加
  4. LG Chocolate Sliding Mechanism Replacement, Sliding Front: 手順 4、 1の画像 1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
    FixBotに聞いてみる
    コメントを追加
  5. LG Chocolate Sliding Mechanism Replacement: 手順 5、 2の画像 1 LG Chocolate Sliding Mechanism Replacement: 手順 5、 2の画像 2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
    FixBotに聞いてみる
    コメントを追加
  6. LG Chocolate Sliding Mechanism Replacement: 手順 6、 2の画像 1 LG Chocolate Sliding Mechanism Replacement: 手順 6、 2の画像 2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
    FixBotに聞いてみる
    コメントを追加
  7. LG Chocolate Sliding Mechanism Replacement: 手順 7、 1の画像 1
    • Pry off the back cover from the front of the case using a plastic opening tool.
    FixBotに聞いてみる
    コメントを追加
  8. LG Chocolate Sliding Mechanism Replacement, Sliding Mechanism: 手順 8、 1の画像 1
    • Use a Phillips #00 to remove the 4 screws that hold the sliding mechanism in place.
    FixBotに聞いてみる
    コメントを追加
  9. LG Chocolate Sliding Mechanism Replacement: 手順 9、 1の画像 1
    • Remove sliding mechanism.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Thomas
メンバー登録日: 01/18/13
91 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S19G46
4 メンバー
44のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 47
今までの合計 839
