メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG Ally VS740 Camera Flash Replacement
必要な工具と部品
  1. LG Ally VS740 Camera Flash Replacement, Camera Flash: 手順 1、 1の画像 1
    • Hold phone in hand, then flip to battery pack
    • Take off battery cover
    FixBotに聞いてみる
    コメントを追加
  2. LG Ally VS740 Camera Flash Replacement: 手順 2、 1の画像 1
    • Remove battery
    • Locate the six surrounding screws located on the edge of the inner compartment, including the two screws on the metal piece where the battery was once placed.
    FixBotに聞いてみる
    コメントを追加
  3. LG Ally VS740 Camera Flash Replacement: 手順 3、 1の画像 1
    • Slide the phone open. Notice on the edges around the keyboard, there is a thick casing. Remove this casing, instructions below…
    • Placing two dominant fingers on the back plate where the battery was, use your thumb finger nail (or prying utensil) and place it on the edge of this thin casing. Firmly, push down with your finger nail (prying utensil) around the casing from left to right. Disconnect casing from keyboard section. Flip the phone over and remove it.
    FixBotに聞いてみる
    コメントを追加
  4. LG Ally VS740 Camera Flash Replacement: 手順 4、 2の画像 1 LG Ally VS740 Camera Flash Replacement: 手順 4、 2の画像 2
    • Using your prying tool, lift the green circuit board platform off the black casing and gently disconnect the connection point between the tether and the green circuit board.
    • Flip phone over, and notice where the camera lies on the other side, there are three small clips connecting a black casing over the section of the phone. Gently using your hands or the prying tool, take these clips off.
    FixBotに聞いてみる
    コメントを追加
  5. LG Ally VS740 Camera Flash Replacement: 手順 5、 1の画像 1
    • The white rectangle with the yellow square is the flash. Gently lift up and disconnect flash module. Take your new flash and aligning the connection point to the connection hole, push it down firmly until it is snug in place. Follow the steps backwards to put phone back together.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Billy Carias
メンバー登録日: 10/23/14
219 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 5-6, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-6, Vijaybhaskar Fall 2014人のメンバー
UMASSD-VIJAYBHASKAR-F14S5G6
3 メンバー
16のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 17
今までの合計 722
