はじめに
In this guide, you will be taught how to successfully replace the LCD screen on your camera.
必要な工具と部品
Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
ある他の人がこのガイドを完成しました。
