メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
KitchenAid Professional 600 Power Cord Replacement
必要な工具と部品
  1. KitchenAid Professional 600 Power Cord Replacement, Top Cover: 手順 1、 1の画像 1
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
    FixBotに聞いてみる
    コメントを追加
  2. KitchenAid Professional 600 Power Cord Replacement: 手順 2、 1の画像 1
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
    FixBotに聞いてみる
    コメントを追加
  3. KitchenAid Professional 600 Power Cord Replacement: 手順 3、 1の画像 1
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
    FixBotに聞いてみる
    コメントを追加
  4. KitchenAid Professional 600 Power Cord Replacement, Speed Selector: 手順 4、 1の画像 1
    • Locate the selector switch.
    • Remove the two Phillips #2 screws holding the selector switch in place.
    FixBotに聞いてみる
    コメントを追加
  5. KitchenAid Professional 600 Power Cord Replacement: 手順 5、 3の画像 1 KitchenAid Professional 600 Power Cord Replacement: 手順 5、 3の画像 2 KitchenAid Professional 600 Power Cord Replacement: 手順 5、 3の画像 3
    • Unplug the cords attaching the drive motor to the switch.
    • We suggest numbering them left from right so they are reattached to the replacement part in the right order.
    FixBotに聞いてみる
    コメントを追加
  6. KitchenAid Professional 600 Power Cord Replacement: 手順 6、 1の画像 1
    • Pull out the Selector Switch.
    FixBotに聞いてみる
    コメントを追加
  7. KitchenAid Professional 600 Power Cord Replacement, Drive Motor: 手順 7、 1の画像 1
    • Remove the two Phillips #2 screws holding the motor in place, located near the fan at the back of the motor.
    • The picture only shows one of the screws. The other screw is located on the exact opposite side of the motor.
    FixBotに聞いてみる
    コメントを追加
  8. KitchenAid Professional 600 Power Cord Replacement: 手順 8、 1の画像 1
    • Pull upward to remove the motor.
    FixBotに聞いてみる
    コメントを追加
  9. KitchenAid Professional 600 Power Cord Replacement, Power Cord: 手順 9、 1の画像 1
    • Remove the Phillips #2 screw attaching the green grounding wire to the frame of the mixer.
    FixBotに聞いてみる
    コメントを追加
  10. KitchenAid Professional 600 Power Cord Replacement: 手順 10、 1の画像 1
    • Remove the three Phillips #2 screws that connect the top portion of the mixer to the "neck" of the mixer.
    FixBotに聞いてみる
    コメントを追加
  11. KitchenAid Professional 600 Power Cord Replacement: 手順 11、 1の画像 1
    • Remove the top portion of the mixer from the "neck" of the mixer.
    • This will make removing the power cord much easier.
    FixBotに聞いてみる
    コメントを追加
  12. KitchenAid Professional 600 Power Cord Replacement: 手順 12、 1の画像 1
    • You can now remove the power cord from the mixer.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Luke
メンバー登録日: 04/11/16
1,380 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 25-4, Maness Spring 2016 Cal Poly, Team 25-4, Maness Spring 2016人のメンバー
CPSU-MANESS-S16S25G4
4 メンバー
27のガイドは作成済み
2件のガイドコメント
So helpful thank you. I've got my mixer cord changer and the mixer is working now. Unfortunately there's always only one speed, high. Any suggestions?
Britter C - 返信 共有
Any idea where I can buy the power cord itself?
Jaeger Amzallag - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 77
今までの合計 7,389
