メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Keychron K10 Max Wireless Mechanical Key Switch Replacement
必要な工具と部品
  1. Keychron K10 Max Wireless Mechanical Key Switch Replacement, Keycap: 手順 1、 3の画像 1 Keychron K10 Max Wireless Mechanical Key Switch Replacement, Keycap: 手順 1、 3の画像 2 Keychron K10 Max Wireless Mechanical Key Switch Replacement, Keycap: 手順 1、 3の画像 3
    • Lay the keyboard face down on the workspace.
    • Use a 2.5 mm hex screwdriver to remove the eight 4.5 mm screws from the back case.
    • Carefully separate the front frame from the keyboard and set it aside.
    • There is a clear shield that sits right above the arrow keys. This shield is to diffuse the LEDs from the keyboard, and it can fall out easily. Just remember to put it back if it does when reassembly.
    FixBotに聞いてみる
    コメントを追加
  2. Keychron K10 Max Wireless Mechanical Key Switch Replacement: 手順 2、 2の画像 1 Keychron K10 Max Wireless Mechanical Key Switch Replacement: 手順 2、 2の画像 2
    • Slide the keycap puller over the keycap until it grips underneath.
    • Pull straight upward to remove the keycap.
    • Sometimes the mechanical switch itself comes with the keycap. Just remove the switch from the button and reinstall the switch.
    FixBotに聞いてみる
    コメントを追加
  3. Keychron K10 Max Wireless Mechanical Key Switch Replacement, Mechanical Key Switch: 手順 3、 2の画像 1 Keychron K10 Max Wireless Mechanical Key Switch Replacement, Mechanical Key Switch: 手順 3、 2の画像 2
    • Place the switch puller around the two small tabs on the front and back of the switch.
    • Squeeze the switch puller to release the tabs, then pull straight upward to remove the switch.
    • The photos show red mechanical switches, but your keyboard may have a different switch color. The removal process is the same for this style of hot-swappable mechanical switch.
    FixBotに聞いてみる
    コメントを追加
  4. Keychron K10 Max Wireless Mechanical Key Switch Replacement: 手順 4、 3の画像 1 Keychron K10 Max Wireless Mechanical Key Switch Replacement: 手順 4、 3の画像 2 Keychron K10 Max Wireless Mechanical Key Switch Replacement: 手順 4、 3の画像 3
    • The replacement switch is oriented to fit only one way.
    • Align the copper pins on the bottom of the switch with the socket.
    • Make sure the copper pins are aligned before pressing the switch into place. Installing the switch in the wrong orientation can bend or break the pins.
    • Press the switch straight down until it clicks into place.
    • The switch should sit flush with the surrounding switches and the keyboard frame.
    FixBotに聞いてみる
    コメントを追加
終わりに
Once the switch is installed, you can reassemble your device back to normal. To reassemble your device, follow these instructions in reverse order.
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Richard Witkowski
メンバー登録日: 03/23/26
595 ポイント
5のガイドは作成済み
チーム
Purdue University Northwest, Team 7-8, Dieterle Spring 2026 Purdue University Northwest, Team 7-8, Dieterle Spring 2026人のメンバー
PNW-DIETERLE-S26S7G8
3 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 38
今までの合計 144
