メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Keyboard Keyswitch Replacement How To
  1. Keyboard Keyswitch Replacement How To, Step 1: Grab the tool shown in the image: 手順 1、 1の画像 1
    • First you are gonna want to grab a keycap puller/remover.
    FixBotに聞いてみる
    コメントを追加
    • Do what the video depicts. Pull of the keycap with the keycap remover
    FixBotに聞いてみる
    コメントを追加
  2. Keyboard Keyswitch Replacement How To, Step 3: Grab the Other Tool: 手順 3、 1の画像 1
    • Grab the keyswitch remover shown in the image.
    FixBotに聞いてみる
    コメントを追加
  3. Keyboard Keyswitch Replacement How To, Step 4: Locate the Grooves: 手順 4、 1の画像 1
    • There are 2 grooves on the sides of the keyswitch. Your keyswitch will still be in the keyboard, but I took mine out to show them closer.
    FixBotに聞いてみる
    コメントを追加
    • Grab the 2 grooves with the keyswitch remover like I did. It is important you pull straight up otherwise you could damage our break the pin, which is bad. It may require some force.
    FixBotに聞いてみる
    コメントを追加
  4. Keyboard Keyswitch Replacement How To, Step 6: Grab New Keyswitch: 手順 6、 1の画像 1
    • Grab your new keyswitch, you don't need the old one anymore. Now first you want to make sure you have the proper amount of pins. For example my keyboard has two and the keyswitch also has 2.
    FixBotに聞いてみる
    コメントを追加
    • Grab your new keyswitch and line up the pins with the holes in the keyboard. Press firmly and it should pop into place. It may require a bit of force, but you could have also lined up the pins wrong so always double check. It should not wiggle at all, it should be firm and sending signals.
    FixBotに聞いてみる
    コメントを追加
  5. Keyboard Keyswitch Replacement How To, Step 8: Check Keycap: 手順 8、 1の画像 1
    • The keycap and keyswitch both have the cross hole. They should line up when installing.
    FixBotに聞いてみる
    コメントを追加
    • The keycap should just pop on and it should fit. Make sure that its facing the right way and in the correct position. Now you are finished! it should click, sound and send signals like all the other ones (considering you are replacing all of them, if not it still should send signals and sound and click like the other new ones.)
    FixBotに聞いてみる
    コメントを追加
終わりに
Just rinse and repeat for all the keys you need replaced!
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
SemiNormalHuman
メンバー登録日: 04/16/26
169 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 23
今までの合計 64
