はじめに
To get to the spring the K-cup assembly housing, the lid, and the water pump will need to be removed.
必要な工具と部品
Using a Phillips #2 screwdriver unscrew two 2mm screws.
Once the screws are out, lift up and squeeze the k-cup assembly housing to take it out.
ある他の人がこのガイドを完成しました。
