メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Jazz UltraTab C855 Motherboard Replacement
必要な工具と部品
    1. Jazz UltraTab C855 Motherboard Replacement, Back Cover: 手順 1、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
    2. Jazz UltraTab C855 Motherboard Replacement: 手順 2、 1の画像 1
      • Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
      FixBotに聞いてみる
      コメントを追加
    1. Jazz UltraTab C855 Motherboard Replacement, Motherboard: 手順 3、 1の画像 1
      • Remove the two pieces of tape securing the ribbon cables to the motherboard.
      FixBotに聞いてみる
      コメントを追加
    2. Jazz UltraTab C855 Motherboard Replacement: 手順 4、 1の画像 1
      • Remove the 3 screws at the top of the motherboard.
      FixBotに聞いてみる
      コメントを追加
    3. Jazz UltraTab C855 Motherboard Replacement: 手順 5、 1の画像 1
      • Using a plastic prying tool, lift open the latch that secures the ribbon cable next to the speaker.
      • Pull the ribbon cable out of its connector on the motherboard.
      FixBotに聞いてみる
      コメントを追加
    4. Jazz UltraTab C855 Motherboard Replacement: 手順 6、 1の画像 1
      • Use a plastic prying tool to disconnect the other ribbon cable from the motherboard. This cable belongs to the device's cameras.
      FixBotに聞いてみる
      コメントを追加
    5. Jazz UltraTab C855 Motherboard Replacement: 手順 7、 1の画像 1
      • Disconnect the large ribbon cable from the motherboard. Do this by unlocking the tabs on each side of the connector.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      FixBotに聞いてみる
      コメントを追加
    6. Jazz UltraTab C855 Motherboard Replacement: 手順 8、 1の画像 1
      • Snip the two sets of wires that are attached to the motherboard. Cut the wires as close to the board as possible. This will leave plenty of length to reattach the wires to the new board.
      • Skip this step if you are only removing the motherboard to replace the screen.
      • During reassembly, we recommend soldering or crimping the wires away from the motherboard contacts. You should avoid soldering directly to the motherboard unless absolutely necessary. To learn more about soldering, check out iFixit's Soldering Skills Guide
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
andres maynez
メンバー登録日: 09/15/15
113 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 1-3, Baechle Fall 2015 IUPUI, Team 1-3, Baechle Fall 2015人のメンバー
IUPUI-BAECHLE-F15S1G3
5 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 25
今までの合計 731
