メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Jazz HDV178 Camcorder Lens Replacement
必要な工具と部品
    1. Jazz HDV178 Camcorder Lens Replacement, Back Cover: 手順 1、 1の画像 1
      • On the back of the camcorder, the side opposite of the flip-out screen, there is a section of grooved plastic with a small arrow.
      • Press down on the grooved plastic with your thumbs.
      • Push the back cover in the direction indicated by the small arrow on the grooved plastic. The back cover should slide right off.
      FixBotに聞いてみる
      コメントを追加
    1. Jazz HDV178 Camcorder Lens Replacement, Battery: 手順 2、 1の画像 1
      • Once you have the back cover off, the camcorder should look like this.
      • Look on the battery for a model number to assure that you acquire the correct replacement part.
      • The camcorder model number is located in the red box. Verify that you have a Jazz HDV178.
      FixBotに聞いてみる
      コメントを追加
    2. Jazz HDV178 Camcorder Lens Replacement: 手順 3、 1の画像 1
      • Take the battery out by pulling up on the bottom of the battery. You should be pulling from the side of the camera where the wrist strap is attached.
      FixBotに聞いてみる
      コメントを追加
    1. Jazz HDV178 Camcorder Lens Replacement, Housing: 手順 4、 1の画像 1
      • Remove the camera mount by unscrewing the 4.5 mm screw in the hole.
      • This is the bottom of the camcorder near where the wrist strap connects.
      FixBotに聞いてみる
      コメントを追加
    2. Jazz HDV178 Camcorder Lens Replacement: 手順 5、 1の画像 1
      • Remove the 4.5 mm screw located near the battery slot.
      FixBotに聞いてみる
      コメントを追加
    3. Jazz HDV178 Camcorder Lens Replacement: 手順 6、 1の画像 1
      • Break the glue that attaches the lens cover to the camcorder by sliding the plastic prying tool beneath the circumference of the part.
      • After the glue is broken, remove the lens cover.
      FixBotに聞いてみる
      コメントを追加
    4. Jazz HDV178 Camcorder Lens Replacement: 手順 7、 1の画像 1
      • Use a small plastic pry tool to gently pry off the silver strip on the top of the camera.
      • Make sure to run the tool under the outline of the strip as you pry it off so the plastic does not snap.
      FixBotに聞いてみる
      コメントを追加
    5. Jazz HDV178 Camcorder Lens Replacement: 手順 8、 3の画像 1 Jazz HDV178 Camcorder Lens Replacement: 手順 8、 3の画像 2 Jazz HDV178 Camcorder Lens Replacement: 手順 8、 3の画像 3
      • Locate the side of the camcorder beneath the lens and on the opposite side of the wrist strap.
      • Remove the silver strip using the same process as the previous step.
      • Remove the two 4 mm screws that were hidden under the cover.
      FixBotに聞いてみる
      コメントを追加
    6. Jazz HDV178 Camcorder Lens Replacement: 手順 9、 3の画像 1 Jazz HDV178 Camcorder Lens Replacement: 手順 9、 3の画像 2 Jazz HDV178 Camcorder Lens Replacement: 手順 9、 3の画像 3
      • Pry off the rubbery cap, which covers the buttons. Use the same process as the previous two steps.
      • Slide your prying tool underneath the entire cover to ensure that the glue breaks cleanly and the cover does not snap.
      FixBotに聞いてみる
      コメントを追加
    7. Jazz HDV178 Camcorder Lens Replacement: 手順 10、 1の画像 1
      • Remove the three combined buttons so they are not misplaced.
      FixBotに聞いてみる
      コメントを追加
    8. Jazz HDV178 Camcorder Lens Replacement: 手順 11、 2の画像 1 Jazz HDV178 Camcorder Lens Replacement: 手順 11、 2の画像 2
      • Using a firm hold on both sides of the camcorder, gently pull apart the two halves. Pressure should be evenly distributed across the entire device.
      • If the camcorder does not come apart easily, double check that all of the screws are removed. Return to the previous steps for screw removal if you find a screw that is still attached.
      FixBotに聞いてみる
      コメントを追加
    1. Jazz HDV178 Camcorder Lens Replacement, Lens: 手順 12、 2の画像 1 Jazz HDV178 Camcorder Lens Replacement, Lens: 手順 12、 2の画像 2
      • Remove the big headed 3.5 mm screw that holds the lens in place.
      FixBotに聞いてみる
      コメントを追加
    2. Jazz HDV178 Camcorder Lens Replacement: 手順 13、 2の画像 1 Jazz HDV178 Camcorder Lens Replacement: 手順 13、 2の画像 2
      • Grab the plastic part covering the lens and gently wiggle it out of place to uncover the lens.
      • Be sure to note how the part is attached so that you can replace it correctly.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
8人の作成者と共同で作成されました。
Sean
メンバー登録日: 01/28/11
207 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 7-34, Regan Winter 2011 Cal Poly, Team 7-34, Regan Winter 2011人のメンバー
CPSU-REGAN-W11S7G34
4 メンバー
13のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 33
今までの合計 2,076
