はじめに
This guide will aid the user in the replacement of the power switch for this device. The power switch is the plastic part that is seen outside of the device. This guide is meant to be used if the part is damaged in some way. If the power switch is not responding, there is probably an issue with the motherboard of the device and simply replacing the part may not fix the problem.
必要な工具と部品
Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
Carefully insert the flat end of the spudger into the seam on the top side of the device. Carefully twist the spudger to open the device. Repeat this step at incremental locations around the seam of the device until the two case halves separate.
Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart. Take care not to break the plastic hinge as the battery compartment cover is removed.
