メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Jazz Digi-Stix JDC11 Capture Button Replacement
必要な工具と部品
    1. Jazz Digi-Stix JDC11 Capture Button Replacement, Battery: 手順 1、 2の画像 1 Jazz Digi-Stix JDC11 Capture Button Replacement, Battery: 手順 1、 2の画像 2
      • Flip the device so that the bottom is facing upwards. Using thumb, push the tab on the bottom in the direction indicated by the arrow and then lift the unhinged part of the tab.
      FixBotに聞いてみる
      コメントを追加
    2. Jazz Digi-Stix JDC11 Capture Button Replacement: 手順 2、 1の画像 1
      • Tilt device so that batteries slide out.
      FixBotに聞いてみる
      コメントを追加
    1. Jazz Digi-Stix JDC11 Capture Button Replacement, Capture Button: 手順 3、 3の画像 1 Jazz Digi-Stix JDC11 Capture Button Replacement, Capture Button: 手順 3、 3の画像 2 Jazz Digi-Stix JDC11 Capture Button Replacement, Capture Button: 手順 3、 3の画像 3
      • Carefully insert the flat end of the spudger into the seam on the top side of the device. Carefully twist the spudger to open the device. Repeat this step at incremental locations around the seam of the device until the two case halves separate.
      • Before completely separating the two halves, separate the case from the battery compartment cover, pulling the case apart. Take care not to break the plastic hinge as the battery compartment cover is removed.
      FixBotに聞いてみる
      コメントを追加
    2. Jazz Digi-Stix JDC11 Capture Button Replacement: 手順 4、 3の画像 1 Jazz Digi-Stix JDC11 Capture Button Replacement: 手順 4、 3の画像 2 Jazz Digi-Stix JDC11 Capture Button Replacement: 手順 4、 3の画像 3
      この手順で使用する道具:
      • There are two wires (one red and one black) that could get disconnected from the motherboard when prying the case apart.
      • Gently seperate the two halves of the device.
      • To remove the circuit board from the right section of the device, unscrew the two 5.6 mm Phillips #00 screws.
      • When the screws have been fully unscrewed, use the tweezers to remove them from the device.
      FixBotに聞いてみる
      コメントを追加
    3. Jazz Digi-Stix JDC11 Capture Button Replacement: 手順 5、 1の画像 1
      • Carefully separate the grey side bar from the case and set it aside.
      FixBotに聞いてみる
      コメントを追加
    4. Jazz Digi-Stix JDC11 Capture Button Replacement: 手順 6、 1の画像 1
      • Use the tweezers to grasp the bottom of the capture button. Pull the capture button away from the case and set it aside.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Katelyn Fry
メンバー登録日: 03/11/13
1 ポイント
7のガイドは作成済み
チーム
Clemson, Team 12-3, Benson Spring 2013 Clemson, Team 12-3, Benson Spring 2013人のメンバー
CLEM-BENSON-S13S12G3
3 メンバー
14のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 26
今までの合計 533
