メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Jawbone MINI JAMBOX Side Button Assembly Replacement
必要な工具と部品
    1. Jawbone MINI JAMBOX Side Button Assembly Replacement, Outer Case: 手順 1、 2の画像 1 Jawbone MINI JAMBOX Side Button Assembly Replacement, Outer Case: 手順 1、 2の画像 2
      • Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
      FixBotに聞いてみる
      コメントを追加
    2. Jawbone MINI JAMBOX Side Button Assembly Replacement: 手順 2、 1の画像 1
      • Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
      • Carefully remove the end panel.
      • The tabs which connect the panel are on the short sides.
      • WARNING: you will likely cause cosmetic damage to the end cap.
      FixBotに聞いてみる
      コメントを追加
    3. Jawbone MINI JAMBOX Side Button Assembly Replacement: 手順 3、 1の画像 1
      • Slide out the rubber foot located on the bottom of the case.
      FixBotに聞いてみる
      コメントを追加
    4. Jawbone MINI JAMBOX Side Button Assembly Replacement: 手順 4、 1の画像 1
      • Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
      • This is the only flat topped screw in the speaker, so keep track of which one it is.
      FixBotに聞いてみる
      コメントを追加
    5. Jawbone MINI JAMBOX Side Button Assembly Replacement: 手順 5、 3の画像 1 Jawbone MINI JAMBOX Side Button Assembly Replacement: 手順 5、 3の画像 2 Jawbone MINI JAMBOX Side Button Assembly Replacement: 手順 5、 3の画像 3
      • Push against the side without end cap to slide the internal components out of the case.
      • While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
      • It will be very difficult the first time. There is a rubber seal on the outside of the plastic inner case that creates a lot of friction with the metal outer case.
      FixBotに聞いてみる
      コメントを追加
    1. Jawbone MINI JAMBOX Side Button Assembly Replacement, Side Buttons Assembly: 手順 6、 2の画像 1 Jawbone MINI JAMBOX Side Button Assembly Replacement, Side Buttons Assembly: 手順 6、 2の画像 2
      • Using the standard metal spudger, carefully pry up the top 2 plastic tabs which hold the exterior button and port cover onto the interior plastic frame.
      FixBotに聞いてみる
      コメントを追加
    2. Jawbone MINI JAMBOX Side Button Assembly Replacement: 手順 7、 1の画像 1
      • Using the standard metal spudger, pry up the bottom 2 tabs attaching the other side of the button panel.
      • It should come off after prying up the first tab.
      FixBotに聞いてみる
      コメントを追加
    3. Jawbone MINI JAMBOX Side Button Assembly Replacement: 手順 8、 3の画像 1 Jawbone MINI JAMBOX Side Button Assembly Replacement: 手順 8、 3の画像 2 Jawbone MINI JAMBOX Side Button Assembly Replacement: 手順 8、 3の画像 3
      この手順で使用する道具:
      • Carefully lift out the end panel.
      • Unplug both the connection ribbon and the ZIF or "zero insertion force" ribbon using tweezers or your hands.
      • There is a bit of glue to hold the connection ribbon down.
      FixBotに聞いてみる
      コメントを追加
    4. Jawbone MINI JAMBOX Side Button Assembly Replacement: 手順 9、 1の画像 1
      • Using the spudger, push the button in and create a small gap between the outside structure and the button.
      FixBotに聞いてみる
      コメントを追加
    5. Jawbone MINI JAMBOX Side Button Assembly Replacement: 手順 10、 1の画像 1
      • Using a computer duster, blow any contaminants out from the button junction.
      • Using a q-tip and cleaner, wipe off any stickiness from the buttons, ensuring to prevent excessive moisture.
      • Alternate Reassembly required, read on.
      FixBotに聞いてみる
      コメントを追加
終わりに
To reassemble your device, follow steps 1 through 5 in reverse order.
キャンセル: このガイドを終了できませんでした。
作成者
6人の作成者と共同で作成されました。
Liam McDonnell
メンバー登録日: 04/01/15
559 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 12-1, Lancaster Spring 2015 Cal Poly, Team 12-1, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S12G1
5 メンバー
27のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 34
今までの合計 1,213
