メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
JBL Wave Beam Case Disassembly
必要な工具と部品
    1. JBL Wave Beam Case Disassembly, Heat up the case: 手順 1、 1の画像 1
      • Open up your case and remove the earbuds. Prepare a heat gun at around 150℃, and gently heat up the front part of the case, around where the LED is.
      FixBotに聞いてみる
      コメントを追加
    2. JBL Wave Beam Case Disassembly, Insert a plastic pick: 手順 2、 2の画像 1 JBL Wave Beam Case Disassembly, Insert a plastic pick: 手順 2、 2の画像 2
      • Now try to insert an opening pick into the seam as shown. If you can't get it in, try heating the case more or using a different pick.
      • Slide the pick around the edge of the case until it reaches the back, next to the hinge part. You can apply more heat here if this is too difficult.
      • Repeat with a second opening pick, going round the other side. The second image shows what your case should now look like.
      FixBotに聞いてみる
      コメントを追加
    3. JBL Wave Beam Case Disassembly, Lift out the internals: 手順 3、 1の画像 1
      • Use a plastic tool to lift up the internals as shown
      • If this is too difficult, you might want to use a third pick, and pry around the area under the LED.
      FixBotに聞いてみる
      コメントを追加
    4. JBL Wave Beam Case Disassembly, Remove the electronics: 手順 4、 2の画像 1 JBL Wave Beam Case Disassembly, Remove the electronics: 手順 4、 2の画像 2
      • You should now have removed the outer case. Remove the two Phillips #0 screws next to the exposed USB port.
      • Pull the motherboard directly upwards. Be gentle here, as it is still connected to the glued-down battery
      • Use a plastic tool to pry out the battery, it is attached to the case with a sticky pad. If you have isopropyl alcohol, apply some underneath the battery to loosen the adhesive.
      FixBotに聞いてみる
      コメントを追加
    5. JBL Wave Beam Case Disassembly, Desolder the battery: 手順 5、 1の画像 1
      • The battery is connected to the motherboard with either 3 or 2 solder pads. Use a soldering iron and flux to remove all of them, being careful not to cause any shorts.
      FixBotに聞いてみる
      コメントを追加
      • Solder the black and red wires of your new battery to GND and BATT on the motherboard, respectively. If there is a third wire (temperature sensor) solder it to the NTC pad.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Chris P. Croutonne
メンバー登録日: 07/19/25
1,208 ポイント
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 27
過去 7 日: 97
過去 30 日: 412
今までの合計 2,873
