はじめに
An in depth guide on how to replace the motherboard in case of general unresponsiveness or faulty functionality.
必要な工具と部品
Use a plastic opening tool to pry around the edges of the circular rubber panel.
Take out the four 9mm black PH0 screws from the top and bottom of the device.
Pull off cap by hand.
The outer casing can now be removed.
Remove the tape around the cables on the top of the device.
Remove the cables by lifting up on the black bracket and then pulling the cable out.
Remove two black 9mm PH0 screws from outside of inner casing on each side.
3 の人々がこのガイドを完成させました。
3件のガイドコメント
Excelente, funcionó perfectamente la guia. Compré la bateria y el armado funcionó perfecto. Muchas gracias.
Angel Pérez - 返信 共有
Hey I need JBL pulse motherboard Where can I buy. Please help
