はじめに
If your JBL Go isn't producing quality sound, the woofer may be damaged. Use this guide to carefully remove and replace the faulty woofer.
必要な工具と部品
Use an opening tool to scrape around the outside of the front cover to remove the glue attaching it to the surrounding rubber layer.
Once the front cover is removed, use a T6 screwdriver head to remove the four 9 mm screws on the black cover.
4 の人々がこのガイドを完成させました。
