メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
JBL Charge Battery Replacement
必要な工具と部品
  1. JBL Charge Battery Replacement, Case: 手順 1、 3の画像 1 JBL Charge Battery Replacement, Case: 手順 1、 3の画像 2 JBL Charge Battery Replacement, Case: 手順 1、 3の画像 3
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
    FixBotに聞いてみる
    コメントを追加
  2. JBL Charge Battery Replacement: 手順 2、 2の画像 1 JBL Charge Battery Replacement: 手順 2、 2の画像 2
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
    FixBotに聞いてみる
    コメントを追加
  3. JBL Charge Battery Replacement: 手順 3、 2の画像 1 JBL Charge Battery Replacement: 手順 3、 2の画像 2
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
    FixBotに聞いてみる
    コメントを追加
  4. JBL Charge Battery Replacement: 手順 4、 2の画像 1 JBL Charge Battery Replacement: 手順 4、 2の画像 2
    • Use a spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
    FixBotに聞いてみる
    コメントを追加
  5. JBL Charge Battery Replacement: 手順 5、 2の画像 1 JBL Charge Battery Replacement: 手順 5、 2の画像 2
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  6. JBL Charge Battery Replacement: 手順 6、 2の画像 1 JBL Charge Battery Replacement: 手順 6、 2の画像 2
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
    FixBotに聞いてみる
    コメントを追加
  7. JBL Charge Battery Replacement: 手順 7、 2の画像 1 JBL Charge Battery Replacement: 手順 7、 2の画像 2
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
    FixBotに聞いてみる
    コメントを追加
  8. JBL Charge Battery Replacement, Battery: 手順 8、 1の画像 1
    • Turn your attention to the back casing removed in Step 7.
    FixBotに聞いてみる
    コメントを追加
  9. JBL Charge Battery Replacement: 手順 9、 1の画像 1
    • Using a razor blade, remove the glue holding the battery cable in place.
    • Use multiple vertical cuts to remove pieces of the glue.
    • Be careful not to cut the battery cables.
    FixBotに聞いてみる
    コメントを追加
  10. JBL Charge Battery Replacement: 手順 10、 1の画像 1
    • Remove the foam surrounding the battery cable.
    FixBotに聞いてみる
    コメントを追加
  11. JBL Charge Battery Replacement: 手順 11、 1の画像 1
    • To remove the battery, pull the battery cable through the hole.
    • This entire white piece needs to be replaced (if replacing the aux/usb port).
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
40 の人々がこのガイドを完成させました。
作成者
13人の作成者と共同で作成されました。
Joe Durand
メンバー登録日: 04/01/15
2,313 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 12-4, Lancaster Spring 2015 Cal Poly, Team 12-4, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S12G4
2 メンバー
24のガイドは作成済み
35件のガイドコメント
How i replaced a new battery in myjbl reflect headphone bluetooth
Mohamad Lutfi - 返信 共有
Please I need directions on replacing the battery of my jbl pulse speaker because it charges but doesn't indicate battery charging nor does it work.please I will be ver grateful.
Ifeanyi(kazhbone0147@gmail.com)
Ifeanyi Anaetoh - 返信 共有
I need help.
My speaker no longer takes a charge.
Not even that old
Where do I get replacement battery. And what kind
Rose - 返信 共有
Your instructions state to replace the white cover, but do not say why it has to be replaced. Can you expound, please? Thank you,
Delton Eason Jr - 返信 共有
Hi Delton, that is a good question. The entire cover has to be replaced if one is replacing the aux/USB ports.
You can ignore that note in this battery replacement guide. Good catch!
Joe Durand - 返信 共有
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 88
過去 30 日: 422
今までの合計 239,238
