メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Iomega MiniMax Disassembly
必要な工具と部品
      • Before you begin:
      • If your disk is mounted and running, be sure to eject it from your desktop.
      • Turn power off via the physical switch on the rear of the enclosure.
      • Remove all cables from the rear of the device. Make note of which cables were used in which ports if you have multiple devices and may mix them up. It's best to use the exact same ports to eliminate any potential issues in case you have a bad port.
      FixBotに聞いてみる
      コメントを追加
    1. Iomega MiniMax Disassembly, Remove screws.: 手順 2、 1の画像 1
      • On the rear of the device, remove the 2 philips screws, with a small screwdriver. Screws are both the same.
      • (Sorry for the poor quality photos.)
      FixBotに聞いてみる
      コメントを追加
    2. Iomega MiniMax Disassembly, Loosen upper case.: 手順 3、 2の画像 1 Iomega MiniMax Disassembly, Loosen upper case.: 手順 3、 2の画像 2
      • Using a thin rigid tool (or old credit card), start on the rear, wedge it into the gap between the upper and lower cases as shown.
      • Slowly work your way around the device while gently pulling up on the separating cover.
      • Make sure to use care near the rear center, to avoid breaking a single center tab at this location. By the time you get to the front, the upper case should almost be falling off, and can be easily removed.
      FixBotに聞いてみる
      コメントを追加
    3. Iomega MiniMax Disassembly, Remove upper case.: 手順 4、 3の画像 1 Iomega MiniMax Disassembly, Remove upper case.: 手順 4、 3の画像 2 Iomega MiniMax Disassembly, Remove upper case.: 手順 4、 3の画像 3
      • Remove upper case. One each of the Left, Front, and Right sides, you can see 3 tabs (per side), that were holding the case on. On the rear you will see the fragile clip that should be removed last, if possible.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
13 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
scottbernardis
メンバー登録日: 04/27/11
1,082 ポイント
1ガイドが承認済み
7件のガイドコメント
EXACTLY what I was seeking!
kend - 返信 共有
Thanks for the tip! What kind of internal bus does the drive use, should I want to upgrade it?
Mariano B. - 返信 共有
No idea on the internal bus. Not my area of expertise.
scottbernardis - 返信 共有
The hardest part was finding an old credit card! BTW, the hard drive in my unit is a 2TB Seagate Barracuda LP with a SATA interface. I’m considering replacing it with a SSD.
Jon Noxon - 返信 共有
This is exactly what I was looking for. I have an old one that stopped working and I want to replace the drive.
Noah Preston - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 60
今までの合計 7,866
