メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Insignia Flex 10.1 Screen Replacement
必要な工具と部品
  1. Insignia Flex 10.1 Screen Replacement, Screen: 手順 1、 1の画像 1
    • Please be aware that removing the rear panel from the back of the Flex 10.1 may cause damage to the rear panel.
    FixBotに聞いてみる
    コメントを追加
  2. Insignia Flex 10.1 Screen Replacement: 手順 2、 2の画像 1 Insignia Flex 10.1 Screen Replacement: 手順 2、 2の画像 2
    • The rear panel is secured to the front case by 26 clips attached to the rear panel. These clips lock onto small tabs machined into the front case.
    • To help in visualization, the 9 clips boxed in orange are located on the same side as the volume buttons.
    • To free the tabs, they must be pushed toward the center of the device. When using the plastic opening tool to free the rear panel, be sure to work the tool at the location of these clips.
    • Remove back cover by inserting a plastic opening tool along the edge of the device to release the clips.
    FixBotに聞いてみる
    コメントを追加
  3. Insignia Flex 10.1 Screen Replacement: 手順 3、 1の画像 1
    • Opening the Flex 10.1 can be challenging. Don't get discouraged if it takes multiple attempts before the Flex 10.1 is opened.
    • Insert the plastic opening tool into the seam between the front case and the rear panel of the Flex 10.1.
    • Gently enlarge the existing gap by pressing and wiggling the plastic opening tool into the gap near each of the clips attached to the rear case, pushing the clips toward the center of the device until the clips have been freed.
    • Repeat the same procedure to free all clips around the Flex 10.1.
    FixBotに聞いてみる
    コメントを追加
  4. Insignia Flex 10.1 Screen Replacement: 手順 4、 1の画像 1
    • After ensuring all clips are free, separate the two halves of the Flex 10.1.
    • The rear panel is now free from the Flex 10.1.
    FixBotに聞いてみる
    コメントを追加
  5. Insignia Flex 10.1 Screen Replacement: 手順 5、 1の画像 1
    • With the rear panel removed, the back side of the Flex 10.1 should look like this.
    FixBotに聞いてみる
    コメントを追加
  6. Insignia Flex 10.1 Screen Replacement: 手順 6、 1の画像 1
    • Peel off the tape covering the two connections labeled in red.
    FixBotに聞いてみる
    コメントを追加
  7. Insignia Flex 10.1 Screen Replacement: 手順 7、 3の画像 1 Insignia Flex 10.1 Screen Replacement: 手順 7、 3の画像 2 Insignia Flex 10.1 Screen Replacement: 手順 7、 3の画像 3
    • Remove the ribbon cable by lifting up on the connection with a plastic opening tool and pulling out the ribbon cable.
    FixBotに聞いてみる
    コメントを追加
  8. Insignia Flex 10.1 Screen Replacement: 手順 8、 3の画像 1 Insignia Flex 10.1 Screen Replacement: 手順 8、 3の画像 2 Insignia Flex 10.1 Screen Replacement: 手順 8、 3の画像 3
    FixBotに聞いてみる
    コメントを追加
  9. Insignia Flex 10.1 Screen Replacement: 手順 9、 2の画像 1 Insignia Flex 10.1 Screen Replacement: 手順 9、 2の画像 2
    • Use a Phillips #0 screwdriver to unscrew the 17 screws labeled in red.
    FixBotに聞いてみる
    コメントを追加
  10. Insignia Flex 10.1 Screen Replacement: 手順 10、 2の画像 1 Insignia Flex 10.1 Screen Replacement: 手順 10、 2の画像 2
    • Separate the whole assembly from the screen, being careful and ensuring you removed everything necessary.
    FixBotに聞いてみる
    コメントを追加
  11. Insignia Flex 10.1 Screen Replacement: 手順 11、 1の画像 1
    • With the screws and white plastic cover removed, the screen and glass panel is exposed.
    FixBotに聞いてみる
    コメントを追加
  12. Insignia Flex 10.1 Screen Replacement: 手順 12、 2の画像 1 Insignia Flex 10.1 Screen Replacement: 手順 12、 2の画像 2
    • Peel back the ribbon cable resting on the screen.
    FixBotに聞いてみる
    コメントを追加
  13. Insignia Flex 10.1 Screen Replacement: 手順 13、 3の画像 1 Insignia Flex 10.1 Screen Replacement: 手順 13、 3の画像 2 Insignia Flex 10.1 Screen Replacement: 手順 13、 3の画像 3
    • Remove the tape covering the connection.
    • Disconnect the ribbon cable from the screen by lifting up on the connection and pulling out the ribbon cable.
    FixBotに聞いてみる
    コメントを追加
  14. Insignia Flex 10.1 Screen Replacement: 手順 14、 3の画像 1 Insignia Flex 10.1 Screen Replacement: 手順 14、 3の画像 2 Insignia Flex 10.1 Screen Replacement: 手順 14、 3の画像 3
    • The screen is now free. Lift the screen out of the glass panel. The screen can now be replaced.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
William Boyden
メンバー登録日: 03/07/16
388 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 2-1, Isaacson Spring 2016 UMass Dartmouth, Team 2-1, Isaacson Spring 2016人のメンバー
UMASSD-ISAACSON-S16S2G1
3 メンバー
11のガイドは作成済み
2件のガイドコメント
What % is there that you'll damage the board in the process of trying to fix the screen?
pepper6540.pah - 返信 共有
If it cost $100 to take you a repair shop i'd probably try myself seeing that i only payed 100 for it, and if it don't work I'm still in same boat with a broke sceen on my Insignia Flex
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 32
今までの合計 8,288
