メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
InFocus LP540 Projector Main Board Replacement
必要な工具と部品
    1. InFocus LP540 Projector Main Board Replacement, Main Board: 手順 1、 3の画像 1 InFocus LP540 Projector Main Board Replacement, Main Board: 手順 1、 3の画像 2 InFocus LP540 Projector Main Board Replacement, Main Board: 手順 1、 3の画像 3
      • Flip the projector right-side up and turn it so that the back ports are facing you.
      • Remove the 7 mm metallic screws using the flat-head screwdriver.
      • Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
      FixBotに聞いてみる
      コメントを追加
    2. InFocus LP540 Projector Main Board Replacement: 手順 2、 2の画像 1 InFocus LP540 Projector Main Board Replacement: 手順 2、 2の画像 2
      • Flip the projector over.
      • Use the T10 Torx screwdriver head to remove the two 77mm screws located nearest to the back panel ports.
      • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
      • Flip the projector back over.
      • Lift up the main lid cautiously to avoid ripping the electrical ribbons.
      FixBotに聞いてみる
      コメントを追加
    3. InFocus LP540 Projector Main Board Replacement: 手順 3、 3の画像 1 InFocus LP540 Projector Main Board Replacement: 手順 3、 3の画像 2 InFocus LP540 Projector Main Board Replacement: 手順 3、 3の画像 3
      • Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
      • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
      • Remove the top cover.
      FixBotに聞いてみる
      コメントを追加
    4. InFocus LP540 Projector Main Board Replacement: 手順 4、 2の画像 1 InFocus LP540 Projector Main Board Replacement: 手順 4、 2の画像 2
      • Hold down the release tabs to remove the cables from the white tabs.
      FixBotに聞いてみる
      コメントを追加
    5. InFocus LP540 Projector Main Board Replacement: 手順 5、 3の画像 1 InFocus LP540 Projector Main Board Replacement: 手順 5、 3の画像 2 InFocus LP540 Projector Main Board Replacement: 手順 5、 3の画像 3
      • Use the T10 Torx screwdriver to remove the five 5mm screws located throughout the motherboard.
      • Pull up the five metal tabs located at the rear of the projector.
      • Do not pull up on the metal tabs too hard or too fast because they can break easily.
      FixBotに聞いてみる
      コメントを追加
    6. InFocus LP540 Projector Main Board Replacement: 手順 6、 3の画像 1 InFocus LP540 Projector Main Board Replacement: 手順 6、 3の画像 2 InFocus LP540 Projector Main Board Replacement: 手順 6、 3の画像 3
      • Remove the three gold ribbons by flipping up the black taps that hold the ribbon in place.
      • Pull the ribbons out carefully and place them under the main board.
      • Carefully lift the entire main board up.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Jorge L Navarro
メンバー登録日: 01/22/14
533 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 13-17, Regan Winter 2014 Cal Poly, Team 13-17, Regan Winter 2014人のメンバー
CPSU-REGAN-W14S13G17
6 メンバー
15のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 27
今までの合計 2,663
