メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
InFocus LP435Z Power Supply Replacement
必要な工具と部品
  1. InFocus LP435Z Power Supply Replacement, External Shell: 手順 1、 2の画像 1 InFocus LP435Z Power Supply Replacement, External Shell: 手順 1、 2の画像 2
    • Place the projector on its back (buttons down) with the lens facing away from you.
    • Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
    • Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  2. InFocus LP435Z Power Supply Replacement: 手順 2、 2の画像 1 InFocus LP435Z Power Supply Replacement: 手順 2、 2の画像 2
    • Use the plastic opening tools to push down the clips holding the lamp cover in place, and remove it.
    • There is no lamp assembly in the projector used in this guide, yours may appear different.
    FixBotに聞いてみる
    コメントを追加
  3. InFocus LP435Z Power Supply Replacement: 手順 3、 2の画像 1 InFocus LP435Z Power Supply Replacement: 手順 3、 2の画像 2
    • Remove the two 8.5mm rear screws holding the rear case plate to the projector using the Phillips #1 screwdriver.
    • Pull the rear plate straight off and set it aside.
    FixBotに聞いてみる
    コメントを追加
  4. InFocus LP435Z Power Supply Replacement: 手順 4、 3の画像 1 InFocus LP435Z Power Supply Replacement: 手順 4、 3の画像 2 InFocus LP435Z Power Supply Replacement: 手順 4、 3の画像 3
    • Flip the projector over and turn around so that the lens faces you.
    • Twist the gray zoom adjustment ring clockwise and extend the lens all the way out, and then slide the zoom adjustment ring all the way towards the end of the lens as far as it will go.
    • Slide the front case plate towards the loosened zoom adjustment ring, until the top plate of the projector is freed from underneath the lip of the front case plate.
    • The front case plate will not come all the way off due to the zoom adjustment ring obstructing it. It will merely slide forward a bit.
    FixBotに聞いてみる
    コメントを追加
  5. InFocus LP435Z Power Supply Replacement: 手順 5、 2の画像 1 InFocus LP435Z Power Supply Replacement: 手順 5、 2の画像 2
    • Lift away the top case plate and set it aside.
    FixBotに聞いてみる
    コメントを追加
  6. InFocus LP435Z Power Supply Replacement, Power Supply: 手順 6、 1の画像 1
    • Remove the four T10 Torx 8.5 mm screws holding the DLP board in place.
    FixBotに聞いてみる
    コメントを追加
  7. InFocus LP435Z Power Supply Replacement: 手順 7、 1の画像 1
    • Unplug the small ribbon cable attaching the DLP board to the motherboard.
    FixBotに聞いてみる
    コメントを追加
  8. InFocus LP435Z Power Supply Replacement: 手順 8、 2の画像 1 InFocus LP435Z Power Supply Replacement: 手順 8、 2の画像 2
    • Detach the DLP board from where it is connected to the motherboard by a large 100 pin connector.
    • Pry up gently while wiggling from left to right if needed.
    • The ribbon cable on the other side of the board could break if pulled too hard.
    FixBotに聞いてみる
    コメントを追加
  9. InFocus LP435Z Power Supply Replacement: 手順 9、 1の画像 1
    • Remove the 2 remaining T10 Torx 8mm screws securing the motherboard to the power supply.
    FixBotに聞いてみる
    コメントを追加
  10. InFocus LP435Z Power Supply Replacement: 手順 10、 1の画像 1
    • Remove all other cables connected to the motherboard.
    • Remove the Speaker Cable
    FixBotに聞いてみる
    コメントを追加
  11. InFocus LP435Z Power Supply Replacement: 手順 11、 1の画像 1
    • Remove Secondary Fan Cable
    FixBotに聞いてみる
    コメントを追加
  12. InFocus LP435Z Power Supply Replacement: 手順 12、 1の画像 1
    • Flip up the DLP board, leaving it attached to the large ribbon cable.
    • Remove DLP Power Cable.
    FixBotに聞いてみる
    コメントを追加
  13. InFocus LP435Z Power Supply Replacement: 手順 13、 2の画像 1 InFocus LP435Z Power Supply Replacement: 手順 13、 2の画像 2
    • Pry out the DLP support piece by gently wiggling it side to side while applying a steady pull. It will slide out.
    FixBotに聞いてみる
    コメントを追加
  14. InFocus LP435Z Power Supply Replacement: 手順 14、 3の画像 1 InFocus LP435Z Power Supply Replacement: 手順 14、 3の画像 2 InFocus LP435Z Power Supply Replacement: 手順 14、 3の画像 3
    • Remove the two 1/4" screws using the nut driver.
    • The second screw is located behind the right side of the 100 pin connector.
    • Gently pry up the motherboard from the connector on top of the power supply.
    FixBotに聞いてみる
    コメントを追加
  15. InFocus LP435Z Power Supply Replacement: 手順 15、 2の画像 1 InFocus LP435Z Power Supply Replacement: 手順 15、 2の画像 2
    • Disconnect the lamp power supply cables from the top of the lamp housing, by gently pulling the two wires in opposite directions.
    FixBotに聞いてみる
    コメントを追加
  16. InFocus LP435Z Power Supply Replacement: 手順 16、 3の画像 1 InFocus LP435Z Power Supply Replacement: 手順 16、 3の画像 2 InFocus LP435Z Power Supply Replacement: 手順 16、 3の画像 3
    • Use your thumbs to pry the sides of the external shell away from the power supply so it can be lifted out.
    FixBotに聞いてみる
    コメントを追加
  17. InFocus LP435Z Power Supply Replacement: 手順 17、 3の画像 1 InFocus LP435Z Power Supply Replacement: 手順 17、 3の画像 2 InFocus LP435Z Power Supply Replacement: 手順 17、 3の画像 3
    • Rotate the power supply so that the main fan enclosure faces to the right, with the motherboard mounting pegs on top.
    • Remove the two #2 Phillips 7mm screws on the side of the power supply.
    • Remove two more #2 Phillips 7mm screws on the opposite side of the power supply.
    • Rotate the power supply so the fan faces towards you, and remove a fifth #2 Phillips 7mm screw from just under the foam pad.
    FixBotに聞いてみる
    コメントを追加
  18. InFocus LP435Z Power Supply Replacement: 手順 18、 2の画像 1 InFocus LP435Z Power Supply Replacement: 手順 18、 2の画像 2
    • Use a plastic prying tool to push the white molex connector through the fan enclosure.
    FixBotに聞いてみる
    コメントを追加
  19. InFocus LP435Z Power Supply Replacement: 手順 19、 2の画像 1 InFocus LP435Z Power Supply Replacement: 手順 19、 2の画像 2
    • Flip the power supply over so that the motherboard mounting pegs are on the bottom.
    • Carefully open the power supply, and be mindful of the cable that will be pulled taut that needs to be disconnected.
    • It may be easier to disconnect this cable if you orient the power supply with the speaker down, so you can reach in more easily.
    FixBotに聞いてみる
    コメントを追加
  20. InFocus LP435Z Power Supply Replacement: 手順 20、 1の画像 1
    • The base of the power supply should now be free.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Andrew Kennedy
メンバー登録日: 01/29/13
186 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 20-3, Maness Winter 2013 Cal Poly, Team 20-3, Maness Winter 2013人のメンバー
CPSU-MANESS-W13S20G3
4 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 20
今までの合計 3,179
