メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
InFocus LP435Z Main Fan Replacement
必要な工具と部品
    1. InFocus LP435Z Main Fan Replacement, External Shell: 手順 1、 2の画像 1 InFocus LP435Z Main Fan Replacement, External Shell: 手順 1、 2の画像 2
      • Place the projector on its back (buttons down) with the lens facing away from you.
      • Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
      • Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    2. InFocus LP435Z Main Fan Replacement: 手順 2、 2の画像 1 InFocus LP435Z Main Fan Replacement: 手順 2、 2の画像 2
      • Use the plastic opening tools to push down the clips holding the lamp cover in place, and remove it.
      • There is no lamp assembly in the projector used in this guide, yours may appear different.
      FixBotに聞いてみる
      コメントを追加
    3. InFocus LP435Z Main Fan Replacement: 手順 3、 2の画像 1 InFocus LP435Z Main Fan Replacement: 手順 3、 2の画像 2
      • Remove the two 8.5mm rear screws holding the rear case plate to the projector using the Phillips #1 screwdriver.
      • Pull the rear plate straight off and set it aside.
      FixBotに聞いてみる
      コメントを追加
    4. InFocus LP435Z Main Fan Replacement: 手順 4、 3の画像 1 InFocus LP435Z Main Fan Replacement: 手順 4、 3の画像 2 InFocus LP435Z Main Fan Replacement: 手順 4、 3の画像 3
      • Flip the projector over and turn around so that the lens faces you.
      • Twist the gray zoom adjustment ring clockwise and extend the lens all the way out, and then slide the zoom adjustment ring all the way towards the end of the lens as far as it will go.
      • Slide the front case plate towards the loosened zoom adjustment ring, until the top plate of the projector is freed from underneath the lip of the front case plate.
      • The front case plate will not come all the way off due to the zoom adjustment ring obstructing it. It will merely slide forward a bit.
      FixBotに聞いてみる
      コメントを追加
    5. InFocus LP435Z Main Fan Replacement: 手順 5、 2の画像 1 InFocus LP435Z Main Fan Replacement: 手順 5、 2の画像 2
      • Lift away the top case plate and set it aside.
      FixBotに聞いてみる
      コメントを追加
    1. InFocus LP435Z Main Fan Replacement, Main Fan: 手順 6、 1の画像 1
      • Remove the four T10 Torx 8.5 mm screws holding the DLP board in place.
      FixBotに聞いてみる
      コメントを追加
    2. InFocus LP435Z Main Fan Replacement: 手順 7、 1の画像 1
      • Unplug the small ribbon cable attaching the DLP board to the motherboard.
      FixBotに聞いてみる
      コメントを追加
    3. InFocus LP435Z Main Fan Replacement: 手順 8、 1の画像 1
      • Remove Secondary Fan Cable
      FixBotに聞いてみる
      コメントを追加
    4. InFocus LP435Z Main Fan Replacement: 手順 9、 2の画像 1 InFocus LP435Z Main Fan Replacement: 手順 9、 2の画像 2
      • Detach the DLP board from where it is connected to the motherboard by a large 100 pin connector.
      • Pry up gently while wiggling from left to right if needed.
      • The ribbon cable on the other side of the board could break if pulled too hard.
      FixBotに聞いてみる
      コメントを追加
    5. InFocus LP435Z Main Fan Replacement: 手順 10、 1の画像 1
      • Remove the 2 remaining T10 Torx 8mm screws securing the motherboard to the power supply.
      FixBotに聞いてみる
      コメントを追加
    6. InFocus LP435Z Main Fan Replacement: 手順 11、 1の画像 1
      • Remove the speaker power cable.
      FixBotに聞いてみる
      コメントを追加
    7. InFocus LP435Z Main Fan Replacement: 手順 12、 1の画像 1
      • Remove DLP Power Cable.
      FixBotに聞いてみる
      コメントを追加
    8. InFocus LP435Z Main Fan Replacement: 手順 13、 2の画像 1 InFocus LP435Z Main Fan Replacement: 手順 13、 2の画像 2
      • Pry out the DLP support piece by gently wiggling it side to side while applying a steady pull. It will slide out.
      FixBotに聞いてみる
      コメントを追加
    9. InFocus LP435Z Main Fan Replacement: 手順 14、 2の画像 1 InFocus LP435Z Main Fan Replacement: 手順 14、 2の画像 2
      • Remove the black plastic retaining clip reinforcing the large ribbon cable connector by prying it from the left edge.
      • Gently pry the large ribbon cable connector from the DLP board, and remove the board.
      • Using too much force could damage the connector.
      FixBotに聞いてみる
      コメントを追加
    10. InFocus LP435Z Main Fan Replacement: 手順 15、 3の画像 1 InFocus LP435Z Main Fan Replacement: 手順 15、 3の画像 2 InFocus LP435Z Main Fan Replacement: 手順 15、 3の画像 3
      • Remove the two 1/4" screws using the nut driver.
      • The second screw is located behind the right side of the 100 pin connector.
      • Gently pry up the motherboard from the connector on top of the power supply.
      FixBotに聞いてみる
      コメントを追加
    11. InFocus LP435Z Main Fan Replacement: 手順 16、 2の画像 1 InFocus LP435Z Main Fan Replacement: 手順 16、 2の画像 2
      • Disconnect the lamp power supply cables from the top of the lamp housing, by gently pulling the two wires in opposite directions.
      FixBotに聞いてみる
      コメントを追加
    12. InFocus LP435Z Main Fan Replacement: 手順 17、 3の画像 1 InFocus LP435Z Main Fan Replacement: 手順 17、 3の画像 2 InFocus LP435Z Main Fan Replacement: 手順 17、 3の画像 3
      • Use your thumbs to pry the sides of the external shell away from the power supply so it can be lifted out.
      FixBotに聞いてみる
      コメントを追加
    13. InFocus LP435Z Main Fan Replacement: 手順 18、 1の画像 1
      • Detach the main fan power cable from the power supply.
      FixBotに聞いてみる
      コメントを追加
    14. InFocus LP435Z Main Fan Replacement: 手順 19、 3の画像 1 InFocus LP435Z Main Fan Replacement: 手順 19、 3の画像 2 InFocus LP435Z Main Fan Replacement: 手順 19、 3の画像 3
      • Use the needle nose pliers to pull out the grommets securing the main fan to its housing.
      • To replace grommets, pull the center pins from their housing, and slip the exteriors of the grommets back into their holes in the fan housing, then push the centers in to secure them in place.
      FixBotに聞いてみる
      コメントを追加
    15. InFocus LP435Z Main Fan Replacement: 手順 20、 1の画像 1
      • Remove the fan from its housing.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Andrew Kennedy
メンバー登録日: 01/29/13
186 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 20-3, Maness Winter 2013 Cal Poly, Team 20-3, Maness Winter 2013人のメンバー
CPSU-MANESS-W13S20G3
4 メンバー
37のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 10
過去 30 日: 37
今までの合計 2,801
