メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
IBM WorkPad c3 Motherboard Replacement
必要な工具と部品
    1. IBM WorkPad c3 Motherboard Replacement, Back Case: 手順 1、 2の画像 1 IBM WorkPad c3 Motherboard Replacement, Back Case: 手順 1、 2の画像 2
      • Turn the device over so that the screen is facing down.
      • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
      FixBotに聞いてみる
      コメントを追加
    2. IBM WorkPad c3 Motherboard Replacement: 手順 2、 1の画像 1
      • Using a hair dryer, slowly heat the edges of the WorkPad.
      • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
      • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
      FixBotに聞いてみる
      コメントを追加
    3. IBM WorkPad c3 Motherboard Replacement: 手順 3、 2の画像 1 IBM WorkPad c3 Motherboard Replacement: 手順 3、 2の画像 2
      • Use a plastic opening tool to pry the back case from the WorkPad.
      • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
      FixBotに聞いてみる
      コメントを追加
    1. IBM WorkPad c3 Motherboard Replacement, Front Case: 手順 4、 2の画像 1 IBM WorkPad c3 Motherboard Replacement, Front Case: 手順 4、 2の画像 2
      • Turn the device over, so that the screen is laying on a flat surface.
      FixBotに聞いてみる
      コメントを追加
    2. IBM WorkPad c3 Motherboard Replacement: 手順 5、 3の画像 1 IBM WorkPad c3 Motherboard Replacement: 手順 5、 3の画像 2 IBM WorkPad c3 Motherboard Replacement: 手順 5、 3の画像 3
      • If the back case has already been removed, carefully place it on the WorkPad to protect the circuitry inside from the heat.
      • Using the hair dryer, slowly heat the edges of the device. Spend at least 1 minute on each side, thoroughly heating the case.
      • The LCD/Digitizer combo is very sensitive to heat, and can easily be ruined if it is directly exposed to the hair dryer. Verify that the screen is face down.
      FixBotに聞いてみる
      コメントを追加
    3. IBM WorkPad c3 Motherboard Replacement: 手順 6、 2の画像 1 IBM WorkPad c3 Motherboard Replacement: 手順 6、 2の画像 2
      • The device will be extremely hot. Use a towel or oven mitt to grab it.
      • Using the Plastic Opening Tools, take the front of the case off.
      • If the case is difficult to remove, try repeating step 2.
      • The power button at the top of the device will be loose once the front part of the case is removed.
      FixBotに聞いてみる
      コメントを追加
    1. IBM WorkPad c3 Motherboard Replacement, Battery: 手順 7、 1の画像 1
      • Remove the yellow tape that is covering the battery connector
      FixBotに聞いてみる
      コメントを追加
    2. IBM WorkPad c3 Motherboard Replacement: 手順 8、 1の画像 1
      この手順で使用する道具:
      • Using the tweezers, carefully disconnect the battery cable from the port
      FixBotに聞いてみる
      コメントを追加
    3. IBM WorkPad c3 Motherboard Replacement: 手順 9、 2の画像 1 IBM WorkPad c3 Motherboard Replacement: 手順 9、 2の画像 2
      • Using the plastic opening tools, lift the battery out of the case
      • The battery is secured with adhesive and it will take some effort to remove
      FixBotに聞いてみる
      コメントを追加
    1. IBM WorkPad c3 Motherboard Replacement, LCD: 手順 10、 2の画像 1 IBM WorkPad c3 Motherboard Replacement, LCD: 手順 10、 2の画像 2
      • Using the spudger lift the tabs holding the LCD/Digitizer combo cables to the WorkPad.
      FixBotに聞いてみる
      コメントを追加
    2. IBM WorkPad c3 Motherboard Replacement: 手順 11、 2の画像 1 IBM WorkPad c3 Motherboard Replacement: 手順 11、 2の画像 2
      • Using your thumb, press down gently on the back of the LCD.
      • The LCD will disconnect and fall out of the case, so be sure to have your hand waiting for it.
      FixBotに聞いてみる
      コメントを追加
    1. IBM WorkPad c3 Motherboard Replacement, Motherboard: 手順 12、 1の画像 1
      • Using the plastic opening tool, lift the clip holding the motherboard cable.
      FixBotに聞いてみる
      コメントを追加
    2. IBM WorkPad c3 Motherboard Replacement: 手順 13、 2の画像 1 IBM WorkPad c3 Motherboard Replacement: 手順 13、 2の画像 2
      • Gripping the motherboard as shown, lift up slightly and pull outward.
      • Small plastic tabs hold the motherboard down. Lifting too hard will break these off, and the motherboard will be loose upon replacement.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Emily Falkenstein
メンバー登録日: 10/05/10
75 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 21-35, Regan Fall 2010 Cal Poly, Team 21-35, Regan Fall 2010人のメンバー
CPSU-REGAN-F10S21G35
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 21
今までの合計 2,422
