メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
IBM Thinkpad T60 LCD Screen Replacement
必要な工具と部品
  1. IBM Thinkpad T60 LCD Screen Replacement, Battery: 手順 1、 1の画像 1
    • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
    • Use your finger to slide the tab to the right to unlock the battery.
    FixBotに聞いてみる
    コメントを追加
  2. IBM Thinkpad T60 LCD Screen Replacement: 手順 2、 2の画像 1 IBM Thinkpad T60 LCD Screen Replacement: 手順 2、 2の画像 2
    • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
    • The battery is now disconnected.
    FixBotに聞いてみる
    コメントを追加
  3. IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: 手順 3、 3の画像 1 IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: 手順 3、 3の画像 2 IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: 手順 3、 3の画像 3
    • Open the laptop so that the screen is facing you.
    • Use a plastic opening tool to pry off the eight plastic screw covers around the display.
    • Note that there are screw covers on the sides (two on the left and one on the right).
    FixBotに聞いてみる
    コメントを追加
  4. IBM Thinkpad T60 LCD Screen Replacement: 手順 4、 1の画像 1
    • Use a #0 Phillips screwdriver to remove the eight 3.25 mm screws uncapped from the previous step.
    FixBotに聞いてみる
    コメントを追加
  5. IBM Thinkpad T60 LCD Screen Replacement: 手順 5、 2の画像 1 IBM Thinkpad T60 LCD Screen Replacement: 手順 5、 2の画像 2
    • Carefully pry the plastic border away from the screen using the plastic opening tool.
    • Note that this step requires some force. There are plastic clips that help hold the border in place so do not worry about snapping sounds.
    FixBotに聞いてみる
    コメントを追加
  6. IBM Thinkpad T60 LCD Screen Replacement: 手順 6、 1の画像 1
    • Use your fingers to pry the screen out of its housing far enough to gain access to the ribbon cables and small screws holding the screen in place.
    FixBotに聞いてみる
    コメントを追加
  7. IBM Thinkpad T60 LCD Screen Replacement: 手順 7、 1の画像 1
    • At the top of the screen, detach the small white clip by pulling it towards you with your finger.
    FixBotに聞いてみる
    コメントを追加
  8. IBM Thinkpad T60 LCD Screen Replacement: 手順 8、 2の画像 1 IBM Thinkpad T60 LCD Screen Replacement: 手順 8、 2の画像 2
    • Using a #0 Phillips screwdriver, remove the 4 mm screw.
    FixBotに聞いてみる
    コメントを追加
  9. IBM Thinkpad T60 LCD Screen Replacement: 手順 9、 2の画像 1 IBM Thinkpad T60 LCD Screen Replacement: 手順 9、 2の画像 2
    • Using a #0 Phillips screwdriver, remove the four 3.25 mm screws
    • The other two screws are in the same position on the opposite side of the display.
    FixBotに聞いてみる
    コメントを追加
  10. IBM Thinkpad T60 LCD Screen Replacement: 手順 10、 2の画像 1 IBM Thinkpad T60 LCD Screen Replacement: 手順 10、 2の画像 2
    • The screen should be free to move now. Let the display rest on the keyboard with the screen facing down.
    • Peel the tape off to expose the LCD connection.
    FixBotに聞いてみる
    コメントを追加
  11. IBM Thinkpad T60 LCD Screen Replacement: 手順 11、 2の画像 1 IBM Thinkpad T60 LCD Screen Replacement: 手順 11、 2の画像 2
    • Turn the inverter over to expose the white clip.
    • Squeeze and pull the wires with your fingers to detach the white clip.
    FixBotに聞いてみる
    コメントを追加
  12. IBM Thinkpad T60 LCD Screen Replacement: 手順 12、 1の画像 1
    • Disconnect the video cable by pulling the grey flat wire. Now the screen is completely separate from the ThinkPad.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
6 の人々がこのガイドを完成させました。
作成者
13人の作成者と共同で作成されました。
Cody Kratochvil
メンバー登録日: 01/11/13
581 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 7-9, Maness Winter 2013 Cal Poly, Team 7-9, Maness Winter 2013人のメンバー
CPSU-MANESS-W13S7G9
4 メンバー
16のガイドは作成済み
1件のガイドコメント
Thanks for the info! ☼
Stck Flw - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 67
今までの合計 13,806
