メインコンテンツにスキップ
Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement
必要な工具と部品
  1. Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement, Rear Glass: 手順 1、 1の画像 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
  2. Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 2、 3の画像 1 Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 2、 3の画像 2 Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 2、 3の画像 3
    • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom right corner.
  3. Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 3、 2の画像 1 Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 3、 2の画像 2
    • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 4、 3の画像 1 Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 4、 3の画像 2 Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 4、 3の画像 3
    • Insert a third opening pick at the bottom left corner.
    • In the next few steps whilst cutting around the rear camera make sure you only use the tip of the opening pick to avoid smearing the lens or damaging the camera.
    • Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 5、 2の画像 1 Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 5、 2の画像 2
    • If the adhesive becomes hard to cut, it most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the back cover.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 6、 2の画像 1 Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 6、 2の画像 2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 7、 2の画像 1 Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 7、 2の画像 2
    • Lift and remove the back cover.
    • Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Secure the new back cover with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
  8. Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement, Motherboard Cover with NFC & Charging Coil: 手順 8、 1の画像 1
    • Remove the ten Phillips #00 screws (4.3 mm length).
  9. Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 9、 2の画像 1 Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 9、 2の画像 2
    • Slide an opening pick under the black adhesive at the bottom right of the charging coil.
    • Carefully loosen the adhesive with the opening pick.
  10. Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 10、 2の画像 1 Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 10、 2の画像 2
    • Slide an opening pick under the black adhesive at the bottom left of the charging coil.
  11. Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 11、 2の画像 1 Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 11、 2の画像 2
    • Slide an opening pick under the left side of the motherboard cover.
    • Unhinge the left side of the motherboard cover by slightly rotating the opening pick.
  12. Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 12、 2の画像 1 Huawei P30 Pro Motherboard Cover with NFC & Charging Coil Replacement: 手順 12、 2の画像 2
    • Push the motherboard cover out of the sockets at the top edge of the phone beginning with the top left corner.
    • Remove the motherboard cover including the NFC and charging coil.
終わりに
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
3 の人々がこのガイドを完成させました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
211,758 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
140 メンバー
18,077のガイドは作成済み
コメント 1 件
Hallo,
erstmal Super Anleitung. Danke dafür.
Ich hätte noch ein paar Fragen. Und zwar ist mein Backcover von meinem Huawei P30 pro nach einem Sturz gebrochen. Ist es möglich, es selber auszuwechseln und dabei den Spritzwasserschutz, sprich den Schutz Ip68 zu erhalten? Und wenn ja, welchen Kleber sollte ich dafür verwenden? Auch wüsste ich gerne, ob es vielleicht reicht die Risse mit dem Kleber zu versiegeln, so dass ich das Backcover gar nicht austauschen muss!?
Sonnige Grüße
Rafael
rafael - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 28
過去 30 日: 103
今までの合計 4,859
