はじめに
In this guide we show you how to replace the front facing camera in your Huawei P10 Plus smartphone.
必要な工具と部品
Use an iOpener to loosen the adhesive beneath the display, focusing on the upper and lower part of the display.
Use an opening pick, or iFlex, to separate the adhesive on all sides of the display.
Place a suction cup, or iSclack, on the upper portion of the phone and lift the display off the midframe.
Don't remove the display, the cable is trapped under a bracket screwed to the phone. You can flip the display to lay it down without straining the cable, or simply hold it in the next steps.
Remove the 3.3 mm-long Phillips screw securing the display flex connector bracket.
Remove the 13 Phillips #00 screws.
Remove the metal shield which holds down the display flex connector.
Peel of the adhesive tape that connects the front facing camera to the mainboard.
Use a spudger to disconnect the front camera flex cable.
Remove the front camera.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
ある他の人がこのガイドを完成しました。
