メインコンテンツにスキップ
Huawei P10 Battery Replacement
必要な工具と部品
  1. Huawei P10 Battery Replacement, Back Cover: 手順 1、 3の画像 1 Huawei P10 Battery Replacement, Back Cover: 手順 1、 3の画像 2 Huawei P10 Battery Replacement, Back Cover: 手順 1、 3の画像 3
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Battery Replacement: 手順 2、 3の画像 1 Huawei P10 Battery Replacement: 手順 2、 3の画像 2 Huawei P10 Battery Replacement: 手順 2、 3の画像 3
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Battery Replacement: 手順 3、 2の画像 1 Huawei P10 Battery Replacement: 手順 3、 2の画像 2
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Huawei P10 Battery Replacement, Battery: 手順 4、 1の画像 1
    • Remove the two Phillips #00 screws.
  5. Huawei P10 Battery Replacement: 手順 5、 2の画像 1 Huawei P10 Battery Replacement: 手順 5、 2の画像 2
    • Use tweezers to remove the two cable brackets.
  6. Huawei P10 Battery Replacement: 手順 6、 3の画像 1 Huawei P10 Battery Replacement: 手順 6、 3の画像 2 Huawei P10 Battery Replacement: 手順 6、 3の画像 3
    • Use a spudger to disconnect the battery, the interconnect and the display flex cable.
  7. Huawei P10 Battery Replacement: 手順 7、 2の画像 1 Huawei P10 Battery Replacement: 手順 7、 2の画像 2
    • The battery is glued in place with two adhesive strips. One with a pull tab and one without.
    • Peel out the adhesive strip which is placed beneath the battery by steadily pulling at the tab in a flat angle.
    • It is likely that the adhesive strip rips. In this case you can grab and twist it around a tweezers tip a couple of times and then continue.
    • Use an iOpener to loosen the remaining adhesive.
  8. Huawei P10 Battery Replacement: 手順 8、 2の画像 1 Huawei P10 Battery Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    Tesa 61395 Tape
    $5.99
    購入する
    • Take care to not bend or puncture the battery.
    • Insert an opening pick or spudger beneath the battery and carefully pry it out.
    • Remove the battery.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
    • Never reinstall a battery that has been bent or damaged during removal.
終わりに
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
75 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
204,379 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,299のガイドは作成済み
16 件のコメント
Thanks for posting this this give me new ideas.
Dave Dayanan - 返信
Facile comme bonjour. Les outils que j'avais reçu avec la batterie étaient de piètre qualité, j'ai donc utilisé des mini-spatules utilisées pour lisser les joints en silicone, c'est pile la consistance voulue pour décoller le dos et la batterie, ni trop ferme ni trop souple.
lepisosteus74 - 返信
Easy fix, thanks a lot.
Noé Barreau - 返信
Excellent guide, was done in 20 minutes, thankyou!
Mog Kupo - 返信
Eccellente guida peccato che una volta montata la nuova batteria in cellulare si sente che si accende la il display rimane buio, controllato connessioni ma sono tutte ok e display sempre spento, cosa può essere?
Adriano
Adriano Da Rold - 返信
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 69
過去 30 日: 302
今までの合計 64,750
