はじめに
Use this guide to remove or replace the loudspeaker in the Huawei Mate 20.
Opening the Huawei Mate 20 will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally but will lose its splash-protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
必要な工具と部品
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
この手順で使用する道具:Tweezers$4.99
Use a pair of tweezers to pry up and disconnect the antenna cable.
Remove the four Phillips #00 screws (3.3 mm length).
Remove the two Phillips #00 screws (3.9 mm length).
ある他の人がこのガイドを完成しました。
