メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to set up a warning triangle
必要な工具と部品
  1. How to set up a warning triangle, Put on a safety vest: 手順 1、 1の画像 1
    • Take a safety vest and put it on. You can usually find one in or near your vehicle safety/first aid kit.
    FixBotに聞いてみる
    コメントを追加
  2. How to set up a warning triangle, Take out the warning triangle: 手順 2、 2の画像 1 How to set up a warning triangle, Take out the warning triangle: 手順 2、 2の画像 2
    • You can usually find your warning triangle in a compartment on the left side of your boot. On some older cars you might also find it in the tailgate or on top of the reserve wheel under the boot.
    • Sometimes the warning triangle and first aid kit come together in a compact combi-pack. Then the warning triangle will be in a red tube in the first aid bag.
    • Since the position of the warning triangle varies from car to car, you should read the manual and memorize where the first aid kit and warning triangle are stashed in your car, before you get into an accident, so that you don’t have to waste time searching.
    FixBotに聞いてみる
    コメントを追加
  3. How to set up a warning triangle, Unpack and unfold the warning triangle: 手順 3、 2の画像 1 How to set up a warning triangle, Unpack and unfold the warning triangle: 手順 3、 2の画像 2
    • Outside the dangerous area, ideally beyond the crash barrier, unpack and fully unfold the warning triangle.
    • Depending on the design, twist the two lower bars in the middle until they form a cross, or fold out the four feet - 2 each at the bottom corners of the triangle - forwards and backwards until the warning triangle can be set up stably.
    • Above the base are the three red bars. Two of them can be pulled up and locked together to form the legs of the triangle. The plastic inner film folds open automatically.
    • In order not to forget the warning triangle when driving off, you should put the packaging on the driver's seat - so you remember it immediately when you get in.
    FixBotに聞いてみる
    コメントを追加
  4. How to set up a warning triangle, Setting up the warning triangle: 手順 4、 1の画像 1
    • Walk towards traffic while keeping the warning triangle visible in front of you, ideally at chest height.
    • Only walk at the very edge of the lane, ideally behind the crash barrier.
    • Now set it up on the roadside - the distance to the vehicle should be around 50 meters in urban areas, 100 meters on country roads and at least 150 meters on the motorway.
    FixBotに聞いてみる
    コメントを追加
終わりに
Drive safe!
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Sebastian
メンバー登録日: 08/19/18
33,392 ポイント
72のガイドは作成済み
1件のガイドコメント
Excellent job describing things most people (and writers) don't think of.
Terra - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 34
過去 30 日: 143
今までの合計 4,538
