メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Troubleshoot a GE Top Load Washing Machine Not Starting
ビデオガイド
この修理ガイドはYouTubeビデオを書き起こしました。
必要な工具と部品
      • Ensure the dial is not stripped or cracked by rotating it and listening for a click.
      • Confirm that pressing the start button produces a click sound from the control board.
      FixBotに聞いてみる
      コメントを追加
      • Examine the lid for any bulging or warping near the striker area.
      • Make sure the striker aligns correctly with the lid lock when the lid closes.
      • Check if the striker is seated flat against the lid and not bent or broken.
      FixBotに聞いてみる
      コメントを追加
      • Look for clogged mesh filters in the water inlet valves at the back of the machine.
      • Verify that both hot and cold water supply hoses are providing adequate flow.
      • Remove any debris blocking the valves to ensure proper water supply.
      FixBotに聞いてみる
      コメントを追加
      • Tilt the washer back carefully and look underneath or on the sides for a plastic pouch.
      • Retrieve the technician’s mini-manual for diagnostic codes and wiring schematics.
      • Use an online reference if you cannot find the original tech sheet.
      FixBotに聞いてみる
      コメントを追加
      • Press and hold the start button for ten seconds, then release it to view error codes.
      • Observe which lights blink alongside pause and lid lock indicators to identify errors.
      • Press the start button repeatedly to cycle through stored codes.
      • Compare the light patterns to the tech sheet or an online resource for exact meaning.
      • Rotate the dial to exit error code mode after viewing the codes.
      FixBotに聞いてみる
      コメントを追加
      • Press and hold the start button while turning the selector dial seven increments, then release it.
      • Listen for a click and flashing lights to confirm entry into the field service mode.
      • Turn the dial counterclockwise four clicks until only the sensing fill light is on.
      • Press and hold the start button for three seconds to delete stored error codes.
      • Re-run the machine to capture active codes only, aiding in accurate troubleshooting.
      FixBotに聞いてみる
      コメントを追加
      • Rotate the dial past the error code deletion step to select agitate, spin, or lid lock tests.
      • Use these forced operations to confirm which component fails to function properly.
      • If a mode does not activate, the related part is likely defective.
      FixBotに聞いてみる
      コメントを追加
      • Unplug the washing machine to avoid electrical hazards.
      • Move the unit away from the wall to access the rear panel.
      FixBotに聞いてみる
      コメントを追加
      • Remove two 1/4 inch screws from each side of the top panel rear cover.
      • Slide the back metal housing to the right and pull it away to expose the control board.
      • Detach any cardboard or plastic flaps to access the board and the pressure hose.
      • Unplug the pressure hose from the board if you need to fully remove the console.
      • Remove two long screws on each rear corner to free the lid assembly from the chassis.
      • Snap the console forward and press down on two hidden front clips with a putty knife.
      • Lift the top upward to reveal the lid lock and its wiring harness.
      FixBotに聞いてみる
      コメントを追加
      • Unplug the wiring harness from the lid lock if it is still connected.
      • Release the white plastic bezel by pressing the outside tabs and pushing it out.
      • Use a small screwdriver to press the lock’s top tab and slide the assembly left for removal.
      FixBotに聞いてみる
      コメントを追加
      • Replace the striker if damaged by removing its two mounting screws on the lid.
      • Align any replacement striker so it fits into the same orientation as the old one.
      • Select a matching GE lid lock assembly if needed and ensure it aligns with the bezel.
      FixBotに聞いてみる
      コメントを追加
      • Slide the new lid lock into the opening and secure it with a left-to-right motion.
      • Press the bezel back into place, aligning the guiding peg correctly.
      • Reconnect the lid lock wiring harness and make sure it is fully seated.
      • Close the top panel and press down on the front edge to engage the hidden clips.
      • Reinstall the capacitor, screws, and the back metal plate at the control area.
      • Verify the capacitor wires match their original orientation before closing.
      FixBotに聞いてみる
      コメントを追加
      • Tilt or lay the washing machine on its back, ensuring the drain hose stays above the tub.
      • Support the machine so the lid does not slam open or shut unexpectedly.
      • Use a ratchet to remove the three bottom-cover screws and note the grounding strap.
      • Check the plastic cover for oil stains, belt debris, or broken tabs.
      FixBotに聞いてみる
      コメントを追加
      • Rotate the pulleys by hand and pull the belt away to slip it off both pulleys.
      • Examine the belt for fraying, grease, or any other visible damage.
      • Clean or replace the belt if it shows signs of slipping or excessive wear.
      FixBotに聞いてみる
      コメントを追加
      • Use a 15 mm socket and ratchet to loosen the pulley nut counterclockwise.
      • Pry the pulley off gently with a large screwdriver or a specialized puller tool.
      • Inspect the speed sensor for any belt debris or damage and unplug it if needed.
      • Remove the sensor by pressing the side tabs and sliding it off the motor housing.
      • Reconnect the sensor by aligning tabs, plugging the harness, and securing the red lock tab.
      FixBotに聞いてみる
      コメントを追加
      • Loosen the pulley nut with a socket wrench and tap or pull the pulley off the shaft.
      • Unplug the shifter harness and remove two 3 8 inch screws holding it in place.
      • Support the assembly so the loaded spring does not pop out when the final screw is removed.
      • Check the clutch spring, plastic housing, and shifter assembly for damage or wear.
      • Verify the coil resistance with a multimeter according to the machine’s schematic.
      • Replace any defective parts and reassemble the shifter, spring, and clutch in reverse order.
      FixBotに聞いてみる
      コメントを追加
      • Align the belt on the motor pulley and begin slipping it onto the transmission pulley.
      • Rotate the transmission pulley to help the belt slide fully into place.
      • Reattach the plastic bottom cover using three screws, including the grounding strap.
      • Set the washer upright and reconnect the power supply to confirm operation.
      FixBotに聞いてみる
      コメントを追加
終わりに
After the faulty control, lid-lock, belt, or shifter issue is corrected, run a test cycle and confirm the washer starts and advances normally. Repair didn't go as planned? Ask our Answers community for help.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Ben Schlichter
メンバー登録日: 01/21/25
7,128 ポイント
224のガイドは作成済み
1件のガイドコメント
Thank you for sharing your knowledge on GE repair. You just saved this broke housewife a ton of money I didn't have to begin with. But as OCD calls for clean laundry , I knew there had to be an easier way.... Bless you washer repair man...bless you
BAlexa Berkley - 返信 共有
コメントを追加
統計データ:
過去 24時間: 14
過去 7 日: 97
過去 30 日: 445
今までの合計 4,085
