メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to String a Tennis Racket
必要な工具と部品
    1. How to String a Tennis Racket, Cut the old strings from the tennis racket: 手順 1、 2の画像 1 How to String a Tennis Racket, Cut the old strings from the tennis racket: 手順 1、 2の画像 2
      • Cut the old strings from the tennis racket using a pair of utility scissors and remove them.
      • Be careful not to cut yourself with the ends of the strings.
      FixBotに聞いてみる
      コメントを追加
    2. How to String a Tennis Racket, Place the frame into a stringing machine: 手順 2、 1の画像 1
      • Place the frame into a stringing machine by screwing in the four main screws and pulling the racket tight.
      FixBotに聞いてみる
      コメントを追加
    3. How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: 手順 3、 3の画像 1 How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: 手順 3、 3の画像 2 How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: 手順 3、 3の画像 3
      • Insert the main vertical string into the head of the racket, and thread it down to the neck of the racket and back to the head.
      • Pull and tighten the first main string into a tension rod.
      • The strings should always go under the racquet.
      FixBotに聞いてみる
      コメントを追加
    4. How to String a Tennis Racket, Secure and tighten the end of the string: 手順 4、 2の画像 1 How to String a Tennis Racket, Secure and tighten the end of the string: 手順 4、 2の画像 2
      • Secure and tighten the end of the string by attaching it to the clamp and moving the rod into the horizontal position.
      • Fix the second string utilizing the second clamp and release the first string.
      • Continue threading the main strings and clamping the strings until all holes have been strung.
      • The stringing pattern: Insert and tighten the string, secure the next string with the clamp, and release the previous string.
      FixBotに聞いてみる
      コメントを追加
    5. How to String a Tennis Racket, Knot the main string: 手順 5、 2の画像 1 How to String a Tennis Racket, Knot the main string: 手順 5、 2の画像 2
      • Knot the main string after you have secured all the main strings.
      • Release the tension rod and cut off the remaining string.
      FixBotに聞いてみる
      コメントを追加
    6. How to String a Tennis Racket, Horizontal cross strings: 手順 6、 1の画像 1
      • Insert the horizontal cross strings from the left to the right and back to the left.
      • Secure and tighten the end of the string by attaching it to the clamp and moving the rod into the vertical position.
      • Continue threading the cross strings and clamping the strings until all holes have been strung by applying the stringing pattern.
      • Weave the cross strings by going over and under repeatedly through the main strings.
      FixBotに聞いてみる
      コメントを追加
    7. How to String a Tennis Racket, Knot all the cross strings: 手順 7、 1の画像 1
      • Knot all of the cross strings after you have secured them.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Tzu-Wei
メンバー登録日: 09/19/20
153 ポイント
1ガイドが承認済み
チーム
York University, Team S2-G28, Melo-Thaiss Fall 2020 York University, Team S2-G28, Melo-Thaiss Fall 2020人のメンバー
YORK-MELO-THAISS-F20S2G28
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 47
今までの合計 5,617
