はじめに
Over time, linocut gouges become dull from regular use. Dull blades can tear linoleum, cause uneven cuts, or even lead to hand strain and injuries.
This guide shows you how to safely sharpen and polish both U-shaped and V-shaped gouges using a 1000-grit whetstone and a slipstrop.
It’s designed for beginner printmakers who want smooth, precise carving results in about 20 minutes with basic tools. However, Linocut tools are very sharp. Always handle gouges with care and keep your hands behind the cutting edge while sharpening.
必要な工具と部品
Soak then set up Whetstone
Submerge the whetstone in water for 5 to 10 minutes until air bubbles stop rising.
Place the whetstone on a rubber mat or holder so it stays still while sharpening.
Keep bowl of water nearby to re-wet the whetstone again if it dries.
Sharpen the V-Gouge
Use the flat side of the whetstone for V-shaped gouges.
Lay one side of the V flat against the stone so it’s fully flat.
Slide the tool back and forth 50 to 100 times using light, even pressure.
Turn the tool over and repeat on the opposite side.
Re-wet the stone whenever it starts to dry.
Your linocut gouges should now have a clean, sharp edge ready for smooth carving. Remember to strop your tools briefly after every few sessions to keep them sharp and safe to use. Regular maintenance will make future sharpening much faster and help prevent tool damage.
