メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Repair a Frayed Dell AC Adapter Cable
必要な工具と部品
  1. How to Repair a Frayed Dell AC Adapter Cable, How to Repair a Frayed Dell AC Adapter Cable: 手順 1、 3の画像 1 How to Repair a Frayed Dell AC Adapter Cable, How to Repair a Frayed Dell AC Adapter Cable: 手順 1、 3の画像 2 How to Repair a Frayed Dell AC Adapter Cable, How to Repair a Frayed Dell AC Adapter Cable: 手順 1、 3の画像 3
    • Be sure to unplug the power supply from the wall before doing any work to prevent electric shock.
    • Inspect the frayed power supply end for spots that you can cut off the connector insulation without damaging the wires.
    • Cut the insulation off the connector using wire cutters, scissors, or a sharp knife.
    FixBotに聞いてみる
    コメントを追加
  2. How to Repair a Frayed Dell AC Adapter Cable: 手順 2、 3の画像 1 How to Repair a Frayed Dell AC Adapter Cable: 手順 2、 3の画像 2 How to Repair a Frayed Dell AC Adapter Cable: 手順 2、 3の画像 3
    • There will be two wires in the connector. One wire comes from the inner cable and the other comes from the frayed outer cable. Find the wire associated with the frayed outer cable.
    • Use a small sharp knife, such as hobby knife, to cut the wire free of the plastic casing.
    • Be sure not to cut or damage the wire.
    FixBotに聞いてみる
    コメントを追加
  3. How to Repair a Frayed Dell AC Adapter Cable: 手順 3、 3の画像 1 How to Repair a Frayed Dell AC Adapter Cable: 手順 3、 3の画像 2 How to Repair a Frayed Dell AC Adapter Cable: 手順 3、 3の画像 3
    • Inspect the wires and determine if there are enough strands that can be soldered together to make a safe, reliable connection.
    • If you can make a good connection with the old wires, press them together so there are no strands fraying outward.
    • If there are only a couple wires still connected and the severed ends can not reach each other, or the wire is completely severed, you will need to splice in some new wire.
    FixBotに聞いてみる
    コメントを追加
  4. How to Repair a Frayed Dell AC Adapter Cable: 手順 4、 2の画像 1 How to Repair a Frayed Dell AC Adapter Cable: 手順 4、 2の画像 2
    • Solder the old, or new, wires together, making sure that the solder flows a little past the damaged area.
    • Re-settle the wire back into the white casing as best as possible.
    FixBotに聞いてみる
    コメントを追加
  5. How to Repair a Frayed Dell AC Adapter Cable: 手順 5、 3の画像 1 How to Repair a Frayed Dell AC Adapter Cable: 手順 5、 3の画像 2 How to Repair a Frayed Dell AC Adapter Cable: 手順 5、 3の画像 3
    • Open the Sugru pack, remove the material, and press it around the connector to make a new connector insulator. It is recommended that your new sheath extends at least .5" past the damaged area.
    • You have approximately 30 minutes to work the Sugru. Then allow about 24 hours for it to fully cure.
    FixBotに聞いてみる
    コメントを追加
ゴール
キャンセル: このガイドを終了できませんでした。
29 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Phillip Takahashi
メンバー登録日: 08/22/11
87,893 ポイント
87のガイドは作成済み
1件のガイドコメント
What do you mean by splicing new wire when completely severed?
K Caye - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 142
今までの合計 77,583
