はじめに
Use this guide to open the SteelSeries Stratus Duo controller for repairs and modding.
必要な工具と部品
Use your fingers to remove the sticker located on the back cover of the Stratus Duo.
Use a Y0 Tri-point screwdriver to remove the five 9.3 mm-long screws securing the back cover.
Carefully lift the back cover assembly away from the frame and move it downward to uncover the battery cable and the interconnect cable at the top of the motherboard.
Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
Use a pair of blunt nose tweezers to grab and lift the connector away from the motherboard.
4 の人々がこのガイドを完成させました。
