メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Open and Clean a PlayStation 4
必要な工具と部品
  1. How to Open and Clean a PlayStation 4, Flip over the PS4: 手順 1、 1の画像 1
    • Flip your PS4 upside-down with the back side facing towards you.
    FixBotに聞いてみる
  2. How to Open and Clean a PlayStation 4, Remove the rear stickers: 手順 2、 3の画像 1 How to Open and Clean a PlayStation 4, Remove the rear stickers: 手順 2、 3の画像 2 How to Open and Clean a PlayStation 4, Remove the rear stickers: 手順 2、 3の画像 3
    • Stickers cover the screws securing the PS4's outer case.
    • Use a pair of tweezers to remove the sticker in the center of the back of the PS4, exposing the first screw.
    • Remove the two stickers at the outer edges, exposing two more screws.
    FixBotに聞いてみる
  3. How to Open and Clean a PlayStation 4, Remove the rear case screws: 手順 3、 1の画像 1
    • Remove the three 7.2 mm-long TR8 Torx security screws on the back of the PS4.
    FixBotに聞いてみる
  4. How to Open and Clean a PlayStation 4, Remove the lower case: 手順 4、 2の画像 1 How to Open and Clean a PlayStation 4, Remove the lower case: 手順 4、 2の画像 2
    • Use your thumbs to lift the lower case up and off the PS4.
    • In addition to the three rear screws, the lower case is held in place by plastic clips. You may need to use significant force to release the lower case.
    FixBotに聞いてみる
  5. How to Open and Clean a PlayStation 4, Disconnect the power supply: 手順 5、 2の画像 1 How to Open and Clean a PlayStation 4, Disconnect the power supply: 手順 5、 2の画像 2
    この手順で使用する道具:
    Small Needle Nose Pliers
    $6.99
    • Use a pair of tweezers to pull the power supply cable straight out to disconnect the power supply unit from the motherboard.
    • Depending on the age of your console, this cable might be very firmly connected. If it feels stuck, don't pull on the cables themselves with much force.
    • Use your fingers to grab the white connector head, and wiggle or "walk" the connector out of its socket to disconnect it.
    • In extreme cases, you might need to use needle nose pliers to get a good grip on the connector.
    • Go slow: pulling on the cables themselves might rip them out of the connector.
    FixBotに聞いてみる
  6. How to Open and Clean a PlayStation 4, Remove the power supply unit: 手順 6、 2の画像 1 How to Open and Clean a PlayStation 4, Remove the power supply unit: 手順 6、 2の画像 2
    • Remove three 9.7 mm-long TR8 Torx security screws.
    • Remove two 41 mm-long Phillips screws and brackets.
    FixBotに聞いてみる
  7. How to Open and Clean a PlayStation 4: 手順 7、 3の画像 1 How to Open and Clean a PlayStation 4: 手順 7、 3の画像 2 How to Open and Clean a PlayStation 4: 手順 7、 3の画像 3
    • Lift the power supply straight up and out of the PS4.
    • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it.
    • During reassembly, ensure the prongs are aligned, then press the power supply into place.
    FixBotに聞いてみる
  8. How to Open and Clean a PlayStation 4, Clean the fan: 手順 8、 2の画像 1 How to Open and Clean a PlayStation 4, Clean the fan: 手順 8、 2の画像 2
    この手順で使用する道具:
    Dust Blower
    $19.99
    • Over time, dust will build up inside the fan and on the fan blades.
    • Use a pair of tweezers to grab loose hairs and dust clumps off the fan.
    • Use a small dust blower or light compressed air to blow remaining dust off the fan.
    • Use a finger to keep the fan blades steady—it makes them easier to clean.
    • If there's a layer of grime on the fan blades, use soapy water or isopropyl alcohol on a cotton swab to wipe them off.
    FixBotに聞いてみる
  9. How to Open and Clean a PlayStation 4, Clean the case: 手順 9、 1の画像 1
    この手順で使用する道具:
    Microfiber Cleaning Cloths
    $3.99
    FixBotに聞いてみる
  10. How to Open and Clean a PlayStation 4, Clean vents and hard-to-reach areas: 手順 10、 1の画像 1
    この手順で使用する道具:
    Anti-Static Brush
    $2.99
    • Depending on how dirty your console is, you might need to use a soft-bristle brush to dislodge more dust and grime.
    • Using an anti-static brush or a new toothbrush, clean any dust out of hard-to-reach areas and off the rear vents.
    • Use a dust blower to blow any loose dust out of the console and a cloth to wipe the vents clean.
    FixBotに聞いてみる
  11. How to Open and Clean a PlayStation 4, Clean the heatsink: 手順 11、 2の画像 1 How to Open and Clean a PlayStation 4, Clean the heatsink: 手順 11、 2の画像 2
    • The PS4 draws air through the heatsink fins, and they may clog with dust and debris over time.
    • If you can see dust buildup in the heatsink, dislodge debris with a brush and use a dust blower to blow it clean.
    • Remember: use this time to clean any other dirty internal surfaces before you reseal your console. Happy gaming!
    FixBotに聞いてみる
終わりに
Disassembly or cleaning didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 4 Answers community for help.
48 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Carsten Frauenheim
メンバー登録日: 03/10/20
164,583 ポイント
439のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
25,715のガイドは作成済み
3件のガイドコメント
Thanks for the help now my ps4 runs quetly you Are a plessing.🙂
Martin1234 - 返信 共有
eu limpei a minha e nao voltou a ligar, o que que eu faço
David Almeida - 返信 共有
quem souber de algo ajude pfvr
コメントを追加
統計データ:
過去 24時間: 79
過去 7 日: 783
過去 30 日: 3,640
今までの合計 87,144
